Using and setting Checkbox in a Gallery
  • Using and setting Checkbox in a Gallery
    Posted by John Heck on November 30, 2022 at 2:00 pm
    • John Heck
      November 30, 2022 at 2:00 PM
      I have a Gallery that I have added two checkboxes in two different columns Pass & Fail.Ā  The Pass column uses the Checkbox named chkPass and the Fail column uses the Checkbox named chkFail. When the checkbox in one column is selected, OnCheck event, I want to make the other checkbox false or unchecked.Ā  I have tried using Reset(ThisItem.ChkPass) and Reset(chkPass) in the OnCheck event area for the chkFail checkbox to make sure the chkPass gets set to false and the opposite with when the chkPass checkbox is selected.Ā  I have tried other options in the OnCheck event.Ā  Not certain what I am missing to have one Checkbox affect the other Checkbox when OnCheck or OnUncheck is selected.
      Thank you in advance for your help.
      Kind regards,
      John Heck
    • Tom Woodhill
      December 4, 2022 at 8:20 PM
      Hi John,
      Try setting the “default” property to a variable.
      you can then set this to your desired default value during the screens “onvisible” event.
      if it is just 2 checkboxes you can set the second checkbox’s to !variable
      Let me know how you go or if you want further details,
      Tom Woodhill
      Principal Governance Officer
      Brisbane
    John Heck replied 2 years, 9 months ago 1 Member · 0 Replies
The discussion ‘Using and setting Checkbox in a Gallery’ is closed to new replies.
