Windows 10 and GP2015R2
  • Windows 10 and GP2015R2
    Posted by Unknown Member on January 13, 2017 at 4:15 pm
    • David Klubock
      January 13, 2017 at 4:15 PM
      Hello:
      We are using Great Plains via a remote app and the users local machine is Windows 10.  When they use Great Plains they get an issue when the icon tray on the bottom of the screen flickers and locks up the GP screen periodically . Creates a lot of aggravation for the user.
      Have other users seen this and applied any fixes to resolve this ?
      Tx
      David
      David Klubock
      Business Systems Analyst
      Park Place Technologies
      Marlborough MA
    • Beth Burrell
      January 16, 2017 at 9:13 AM
      What is the server that it is going to?  Windows 2012 r2?  Is it a published app or rdp and then starting the app?
      Beth Burrell
      CRM Customer Success Coach
      Tribridge
      Tampa FL
    • Blair Christensen
      January 16, 2017 at 9:51 AM
      Can you provide more details, such as:
       – version of Dynamics GP
       – client PC OS
       – if .SET files use mapped drives
       – other programs running on host PC
      Windows 10 implemented some security and network tweaks that certainly can cause some application problems.  One thing you might try is seeing if the same setup works but using a Windows 7 box.  That will tell you it is the OS and you can inquire with Microsoft as to the problem.
      Blair Christensen
      Database Administrator
      Oppenheimer Companies, Inc.
      Boise ID
    • Aron Roberts
      January 16, 2017 at 10:31 AM
      I experienced this issue when i first started upgrading users to windows 10. While i never fully solved the problem i did notice it only seemed to happen when alot of different GP tabs are open.
      It also happened with other remoteapps i had deployed. If the users limited the amount of open windows everythong seemed normal.
      Server 2012.
      Windows 10
      No mapped drives.
      Aron Roberts
      Clima-Tech Inc.
      Chino CA
    • Blair Christensen
      January 17, 2017 at 10:01 AM
      It’s almost beginning to sound as if it is a memory limitation.  GP is a memory hog.  You might check on your RD host to see if you can up the memory allocated to each RD session and see if that helps.
      Blair Christensen
      Boise ID
    • Bill Schulz
      January 16, 2017 at 10:34 AM
      I have also seen issues with particular displays. I would note which users have the issue and what monitors they all have. If it is the same monitor model number, that is likely the issue. That would point to a need for a new driver.
      Bill Schulz
      Turnkey Technologies, Inc.
      St. Louis MO
    • Beat Bucher
      January 16, 2017 at 11:59 AM
      Hi David,
      I’ve been using published GP app since serveral years (first on Citrix and then on Windows TS). Our current TS/RDP server is a Win2012 box (since 2 years now) and 99% of my users are running the published GP apps from a windows 7 client PC.. no issues, other than some tricky monitor resolution issues (but that’s a different story).
      I’ve recently traded my laptop for a new Win10 machine and installed GP 2013R2 locally and use the remote publsihed app as well.. no issues at all and no strange flickering of the icon.
      I also run my test GP2016R2 client thru another RDP system from my win10 machine and it behaves not differently than 2013R2..
      Beat Bucher
      Montreal QC/Canada
      +1-514-489-4267
      GP2013R2 / MR2012 CU14
    • Ken Allgood
      January 18, 2017 at 8:24 AM
      Check your event viewer log, see if you have errors with explorer.exe.   It’s an issue with explorer.exe while using the windows 10 RDP client.  We had a very similar issue with RemoteApp with GP and any user on windows 10.  They would be working, and then GP would stop responding..  give it maybe a few seconds, or maybe 2-3 minutes, then it “flashes”, taskbar kinda hides and comes back, and then you can move around again.  If you were really unlucky, it does this almost non-stop.
       We had actually set up the win 7 rdp.exe and DLL’s on windows 10 machines, and that fixed the problem, but would have issues every 2-3 weeks when 1 of the files was updated.
      We worked through Microsoft support (GP support, then RDS, then a Senior Escalation Engineer that immediately saw the problem).  Easiest fix is to apply either the November 2015 update (version 1511) or what’s called the Anniversary Update (August 2, 2016), version 1607.  Both of these updates include the fix to explorer.exe.
      Ken Allgood
      Saratoga Technologies, Inc.
      Johnson City TN
    • Ken Allgood
      January 18, 2017 at 8:33 AM
      Clarification – The update I’m referencing is Windows 10 update/version 1511 & 1607
      Ken Allgood
      Johnson City TN
    Unknown Member replied 8 years, 7 months ago 1 Member · 0 Replies
The discussion ‘Windows 10 and GP2015R2’ is closed to new replies.
