Purge Purchasing Transactions not working correctly
  • Purge Purchasing Transactions not working correctly
    Posted by DSC Communities on December 8, 2016 at 10:00 am
    • xpress global
      December 8, 2016 at 10:00 AM
      Hello everyone,
      In the Fixed Assets Utility menu there is an option for purging purchasing transactions. I have tried to use it several times but the info is still in the drop down menu when I am adding fixed assets in the Card module. Any suggestions for getting these transactions out of the list when they don’t need to be capitalized?
      Melinda
      Melinda Varboncoeur
      Xpress Global Systems
      Chattanooga TN
    • Leslie Vail
      January 2, 2017 at 6:55 AM
      The utility to purge purchasing transactions is intended to be used by those customers who have elected not to delete the purchases upon capitalization. It is not to delete the transactions because you do not want to capitalize them or otherwise want to remove them from the window. This is not a bug, it is working as designed. In order to remove items from the purchases window that are not being capitalized, you need to use SQL to delete them. The FA-AP Posting Master holds the records from the purchases clearing account. Look at table FA01100 for the data.
      Kind regards,
      Leslie
      Leslie Vail
      Dallas TX
    DSC Communities replied 8 years, 8 months ago 1 Member · 0 Replies
The discussion ‘Purge Purchasing Transactions not working correctly’ is closed to new replies.
