GP2016R2 Web Client
  • GP2016R2 Web Client
    Posted by DSC Communities on December 12, 2016 at 4:32 pm
    • Melissa Kovacevich
      December 12, 2016 at 4:32 PM
      I have recently applied the year end update to the GP 2016 web client and now when i click on the link to Enter time for a pay period GP does nothing.   I do not get an error message.  I ran a log file on the web sessions and nothing popped out as the issue.  I have ran a repair on the web client, GP client install on the web server, restarted IIS and the website, rebooted the server.  Anyone have any idea of what could be going on?
      Thanks Much
      Melissa Kovacevich
      Western Technical College
      La Crosse WI
      December 13, 2016 at 8:52 AM
      More Background to the issue …..
      We installed the 2016 Year end update and associated web client patch and everything worked.  We could get into the time cards and back to the home page.  Then I installed a the patch for Management Reporter 2012 CU15 so that is would work with GP2016.  Once I got that to work, then the links for the time cards in the web client did not work.  Interestingly enough, when I log into the GP2016 Client the links for the time card work.
      Melissa Kovacevich
      La Crosse WI
    • Rob Klaproth
      December 13, 2016 at 12:34 PM
      Hi Melissa,
      Which time cards, the PTE project time cards or the HR ones?
      I have the same scenario installed last week, so I can test and see but I need to know which ones.
      ——Original Message——
      Melissa Kovacevich
      La Crosse WI
      December 14, 2016 at 11:04 AM
      we are using the HR time cards
      Melissa Kovacevich
      La Crosse WI
    • Rob Klaproth
      December 14, 2016 at 2:33 PM
      I could not reproduce, it appears to work fine in my instance even with the GP2015 component installed for management reporter to work properly.  I would log a case with Microsoft if you can’t get it working or call your Gp partner.
      Melissa Kovacevich
      La Crosse WI
    • Isaac Olson
      December 13, 2016 at 1:00 PM
      I tested on GP 2016 R2 web client as both a full and self service user, and I could not replicate this with Timecards or Timesheets.  I am curious if anyone else is seeing this or if it is an environmentally specific issue?
      Isaac Olson
      Microsoft
    • Rob Klaproth
      December 13, 2016 at 9:50 PM
      Tested and it works for me.  Make sure you have the workflow activated, the timesheet module doesn’t show up until there is a PTE workflow turned on I think.
      Isaac Olson
      Microsoft
      December 21, 2016 at 3:09 PM
      I have figured it out šŸ™‚
      I had removed the links in the navigation pane for my general public users making the home page the only thing that they could see.  When I did that in GP2016R2 the links didn’t work for the time card.  The HR & Payroll Navigation pane option needs to be visible in order for the time card links to work on the home page.  This is different then the response in GP2015R2.  I could hide all navigation pane options and the time card links still worked.
      Happy Holidays ALL
      Melissa Kovacevich
      La Crosse WI
The discussion ‘GP2016R2 Web Client’ is closed to new replies.
