GP 2018 Vendor email address upload using IM
    January 5, 2024 at 12:15 pm
    I’ve not been able to do it with IM, only with SmartConnect. Is their IM setup with eConnect? That might change the fields if you have not installed eConnect to use with IM.
  • Chris Donnelly
    January 8, 2024 at 9:42 am
    Lisa,
    It’s been a while since I’ve used IM. I do recall embedding SQL statements within the integrations. If you can find where to embed the scripts, IM has a variety of samples for you. I want to say it’s a selection on the line holding a field mapping.
    It takes a little programming skill for the calls and a little SQL skill for the inserts or updates to the table holding the addresses (table sy01200?).
    Good luck!
    Chris
    • Lisa Hunter
      January 8, 2024 at 4:34 pm
      Thank you Jo & Chris, great information and direction, very much appreciated.
  • that canadianguy
    January 9, 2024 at 12:43 pm
    Whats is your source ? is it from another SQL Server database ?
    ive made a Complete algorithm for this
    (linked two servers) and the update is done everyday automaticly
The discussion ‘GP 2018 Vendor email address upload using IM’ is closed to new replies.
