Error message with sales report
  • Error message with sales report
    Posted by Unknown Member on March 23, 2017 at 2:57 pm
    • Deana Davis
      March 23, 2017 at 2:57 PM
      When I am trying to run a sales posting journal report called Receivables Voided/Waived/NSF I get the error message above. Can anyone tell me what it means?
      Deana
      Deana Davis
      Atlantic Corporation Limited
      Halifax
    • Leslie Vail
      March 24, 2017 at 3:15 AM
      This looks like a c-tree error. There’s a file named CTERROR.PDF in the Manuals folder of the Dex program file. In that document, it’s described as:
      FUSE_ERR 46 File number already in use
      If you look in the Programmers Guide on the Faircom website at https://docs.faircom.com/doc/ctreeplus/52855.htm, it describes Error 46 as:
      File number is already in use. If possible, increase the FILES setting in the server (or the fils parameter of INITISAM() for standalone). In releases after V10.3, the default for MAX_FILES_PER_USER has been increased from 2048 to 32767 to avoid file opens failing due to the lower limit.
      Try deleting all of the files in your temp folder.
      Kind regards,
      Leslie
      Leslie Vail
      Dallas TX
    • Bruce Strom
      March 24, 2017 at 8:59 AM
      We sometimes get temp error messages when Great Plains runs long reports, like the HATB reports.  In a Citrix environment, increasing the memory in the Citrix metaframe servers helps with this problem.
      Bruce Strom
      Programmer Analyst
      Associated Grocers of Florida
      sunrise FL
    • Ken Brauchle
      March 24, 2017 at 9:10 AM
      If this is a ctree error you might want to clean out your temp files.
      Ken Brauchle
      The Phoenix Group
      O’Fallon MO
    Unknown Member replied 8 years, 7 months ago 1 Member · 0 Replies
The discussion ‘Error message with sales report’ is closed to new replies.
