DEX.INI value reverting back to its original value.
Posted by DSC Communities on January 9, 2017 at 5:49 am-
Andrew Dean
MemberJanuary 9, 2017 at 5:49 AM
I have a client where a setting in the DEX.INI file is being changed from SuppressChangeDateDialog=TRUE to SuppressChangeDateDialog=FALSE each night. Originally, there was no entry in the DEX.INI file but since adding the entry, it is being changed from TRUE to FALSE each night.
We have a temporary fix by opening the DEX.INI file in NotePad and leaving it open. This stops the value from being updated.
The client has the following third party modules installed : Auditor, SmartList Builder, WennSoft Products, WennSoft Equipment Management, Extender, SmartFill, BankPro, Dynamics Report Manager, Email Pro, PA MULTICOMPANY, GST Wizard, PA System Tools, SmartConnect, Support Debugging Tool, WS Alt Window & Report, Manager, SmartView, Collections Management
Has anyone seen this before and how was it fixed.
Regards
Andrew Dean
Envisage Software Solutions
Robert Cavill
MemberJanuary 9, 2017 at 6:35 AM
Rockton’s Dynamics Report Manager (DRM) may be your culprit.
On the System Settings window for DRME, there is checkbox for “Suppress Date Change Dialog at Midnight”, and when checked, there is radio button to imply whether the value should be TRUE or FALSE.
I found that when it is checked, it will continue to ‘reset’ that DEX.INI based on the radio button selection.
I am using DRME build 12.0.1004, so YMMV.
Support Debugging Tool also has the ability to set the entries in DEX.INI, but that needs to be a deliberate choice to set to FALSE, ( check the DEX.INI Configuration ) .
This is different from the DEX.INI Settings checkbox in SDT to amend the DEX.INI entry to suppress the Sample Company Date.
Robert Cavill
Emeco International Pty Ltd
Osborne Park, Western Australia
Beat Bucher
MemberJanuary 10, 2017 at 9:13 AM
Andrew,
In addition to what Robert mentioned, you may also want to check if you have the PSTL installed on your GP server side (or any client).. that can lead to problems as well with the “Suppress Date Change Dialog at Midnight” option.. Check for following entry in your DYNAMICS.SET file :
1838
Technical Service Tools——————————
Beat Bucher
Montreal QC/Canada
+1-514-489-4267
GP2013R2 / MR2012 CU14
Leslie Vail
MemberJanuary 26, 2017 at 5:40 AM
Beat,
The Dex.ini setting and the PSTL setting work together. The Dex.ini switch keeps the dialog from presenting, but the date doesn’t change. The PSTL tool will change the date. So, if you don’t want the dialog to display, but you do want the user date to change, you’ll need to use both the .ini switch and the PSTL setting.
Kind regards,
Leslie——————————
Leslie Vail
Dallas TX
Beat Bucher
MemberJanuary 27, 2017 at 10:33 AM
Thank you Leslie for the precision.. I wasn’t aware about that š
Now that you mentioned it, I checked back in Richard Whaley’s book about the PSTL, and low & behold, it stated that after enabling the feature in PSTL, you have to edit the DEX.ini too & add the line for the Date Change dialog suppres.
This is a great book and I recommend warmly for every GP Admin to buy a copy.PS: it is with great sadness that I just noticed the site is closing down.. After Richard passed away, the business declined and seems not sustainable anymore.. I wish they would continue to make the books available at least thru a partnership like Amazon or Barns&Noble, to get the electronic versions…
Let them know : http://www.accoladepublications.com/Accolade-Publications-Inc.htmlPS: after posting this reply, I went on to the Amazon site and found out that most of Richard’s book are already availble for purchase there.. though I found one that is very expensive for GP book (and probably a mistake š ):
Beat Bucher
Montreal QC/Canada
+1-514-489-4267
Steve Erbach
MemberJanuary 30, 2017 at 9:31 AM
Béat,It looks like very slim pickings on Amazon, as well. Many of Whaley’s books are marked either:
Usually ships in 1 to 2 months
Temporarily out of stock
Currently unavailableVery sad because these are good books. I refer to the “Information Flow and Posting” book frequently. I’ve actually contacted the seller about that amazing price.
“Sparkly” Steve Erbach – Business Analyst & MS Dynamics Platform Administrator
WOW Logistics – Appleton, WI
VP for Communication, GPUG WI (Milwaukee) Chapter
GP 2016 (16.00.0439)
MR 2012 CU15
Twitter: @serbach
Beat Bucher
MemberJanuary 30, 2017 at 2:33 PM
You’re right Steve,
it’s really only a small subset of teir GP collection… and the most of the links that Amazon brings back are from used-books resellers and/or other distribution channels that sell them for a hefty ‘upcharge’ ..
I contacted Betsey too and was hoping they would at least continue to sell them in eBook format on Amazon or thru another retail online channel.——————————
Beat Bucher
Montreal QC/Canada
+1-514-489-4267
Steve Erbach
MemberJanuary 31, 2017 at 9:01 AM
Béat,I got a reply back from the seller of that incredibly-priced copy of “Information Flow and Posting”:
We list books for a local library and they basically just price match once a quarter. At the time they do reprice they would basically set their price $1 lower than the lowest price regardless of the other sellers condition. If there are no other sellers at the time they price the book and they do not know the market value they will place it high to make sure no one buys it and re-adjust once there are competing offers during the next quarterly pricing.So the seller is acting as a consignment shop for the library, it looks like. At the end of the quarter, I suppose, the library may adjust its asking price. Weird, though, that they couldn’t simply use the list price (on the back cover) to begin with instead of making sure no one buys it… and then when they do know the market price, marking their copy to $1 below the lowest price so that somebody buys it right away…. ? Beats my pair of jacks…
MR 2012 CU15
Twitter: @serbach
Beat Bucher
MemberFebruary 1, 2017 at 9:18 AM
Indeed.. that is very awkward.
The mysteries of online selling :-).——————————
Beat Bucher
Montreal QC/Canada
+1-514-489-4267
David Flowers
MemberJanuary 30, 2017 at 10:09 AM
I have a “Version 10 Unleashed” book by Richard Whaley that I might let go for $4,999. Get ’em while you can! š——————————
David Flowers
System Admin -GP and Salesforce Support
RMG Enterprise Solutions
Addison TX
Andrew Dean
MemberJanuary 19, 2017 at 12:04 AM
Modifying the setting in Rockton’s Dynamics Report Manager did the trick. Thanks to both Robert and Beat for your contribution.
Andrew Dean
Envisage Software
DSC Communities replied 8 years, 11 months ago 1 Member · 0 Replies -
The discussion ‘DEX.INI value reverting back to its original value.’ is closed to new replies.
