Delete batch ID in Create EFT file in Payables Management
  • Delete batch ID in Create EFT file in Payables Management
    Posted by DSC Communities on April 26, 2017 at 12:02 pm
    • Deborah Butters
      April 26, 2017 at 12:02 PM
      I have a batch ID waiting for an EFT file to be generated in Payables Management. I want to delete that batch ID because I don’t want to generate an EFT file. I have been using this batch ID for EFTs generated from the other party so there is no file that needs to be generated. How can I delete these transactions so that it doesn’t keep showing that I need to generate an EFT file? They are valid transactions that have already been posted. I just don’t want to generate the EFT file. Does that make sense?
      Deborah Butters
      Valley Coop Oil Mill
      Harlingen TX
    • Frank Heslin
      April 26, 2017 at 12:56 PM
      Hi Deborah,
      When we have a situation where we have an EFT batch in the Generate EFT file window but we don’t need the file, for whatever reason, I just have my users generate the file & then delete the file from the shared folder so that it doesn’t get sent to the bank accidentally.
      Hope that helps!
      Frank Heslin
      ExamWorks, Inc.
      Atlanta GA
      Member, GPUG Advisory Committee
      Summit 2016 Track Leader
      GPUG All Star 2016
      GP2015 R2
      MR CU14
      Follow me on Twitter: @Automate_It
    • Deborah Butters
      April 26, 2017 at 1:14 PM
      The file won’t generate I’m assuming because I don’t have any banking information entered for the vendors. Do you put in “dummy” information so that it will generate the file? The only thing entered on the vendors for EFT bank is Bank Country/Region: USA
      Deborah Butters
      Harlingen TX
    • Frank Heslin
      April 26, 2017 at 2:21 PM
      That might work.Ā  Just make sure you remove that info when you’re done.
      Frank Heslin
      ExamWorks, Inc.
      Atlanta GA
      GPUG All Star 2016
      GP2015 R2
      MR CU14
    • Edgar Manriquez
      April 27, 2017 at 7:14 AM
      Hi Deborah, is there a message you get when trying to generate the EFT file?
      Best regards,
      Edgar Manriquez
      Assistant Controller
      Schurz Communications, Inc.
      Mishawaka IN
    DSC Communities replied 8 years, 4 months ago 1 Member · 0 Replies
The discussion ‘Delete batch ID in Create EFT file in Payables Management’ is closed to new replies.
