WMS Mobile App – D365 F&O
  • WMS Mobile App – D365 F&O
    Posted by Rod Helmick on December 17, 2024 at 3:49 pm
    Question on doing registrations on the WHS Mobile App. I have items that are setup with batch tracking. If I go into back office, create a PO with a batch item on it for a quantity of 100. When I go in an register this prior to receiving, I can put that batch info in there and it will generate one single batch number regardless of the quantity I’m receiving.
    Now, for the issue. If I do the same thing of creating a PO with a batch item for quantity of 100, and this time I go into the WMS mobile app to do the registration for a quantity of 100, once I confirm this, it generates a batch number for every quantity I’m receiving. In other words, it will create 100 batch numbers. This is wrong and I need it to only create one batch for all 100 items that I’m receiving.
    Is there a configuration to support this or is this just a fundamental flaw in the Mobile App?
    Thx.
    Rod Helmick replied 11 months, 3 weeks ago 2 Members · 2 Replies
  • 2 Replies
  • Paul Pollock
    December 17, 2024 at 3:54 pm
    Down Accepted answer
    Have you reviewed Batch Number Group configuration? This sounds like “Per qty” is setup and maybe you need to investigate using “Only for inventory transactions”. When enabled, a single batch number is generated for the entire inventory transaction, regardless of the quantity. This means that even if you receive items in multiple registrations, they will share the same batch number.
  • Rod Helmick
    December 17, 2024 at 4:37 pm
    Thanks Paul. That worked. Much appreciated.
