AX2012 R3 WMS Work templates/Location directives
  • AX2012 R3 WMS Work templates/Location directives
    Posted by Mark Berg on August 13, 2021 at 9:41 am
    • Mark Berg
      August 13, 2021 at 9:41 AM
      We are setting up Work templates for creating Work for shipments.Ā  When we Release the order to the warehouse, is there a way to not create the Work if there is not enough inventory for the order?Ā  Currently it is telling us that “Shipment xxxx was not fully allocated” which means it only created the shipment for the existing inventory.Ā  We would prefer that the Shipment and Work not be created and receive a message the it was cancelled.
      Mark Berg
      Applications Business Analyst
      Bay Industries Inc.
      Green Bay WI
    • Curt Killian
      August 15, 2021 at 9:56 PM
      A few options to check.
      1)On the warehouse, under reservations – do you have ‘require full reservation’ selected?
      2)If you are using the manual release to WH, you can select a fulfillment policy, after you have added orders to the bottom section of the screen.
      3)Additional options: On your customer master > warehouse fast tab you can set a fulfillment policy and/or check fill entire shipment flag, if you’d like more granular control by customer.
      Curt Killian
      Columbus Global
      FL
    Mark Berg replied 4 years, 7 months ago 1 Member · 0 Replies
The discussion ‘AX2012 R3 WMS Work templates/Location directives’ is closed to new replies.
