Uploading Multiple Item Cross References (instead of one at at time)
Posted by DSC Communities on December 15, 2016 at 4:56 pm-
Nigel Rhodes
MemberDecember 15, 2016 at 4:56 PM
HI all,
I read this blog post on how to Setting up Item Cross Reference for Customers and Vendors. Doing it one by one is fine, but I have 90 SKU’s I need to update (possibly even more going forward). Surely there is a way to do what this blog is saying but in bulk/batch?
Thank you for the help!
ArcherPoint, Inc. remove preview Setting up Item Cross Reference for Customers and Vendors Do you know how to set up Item Cross References for Customers and Vendors in Microsoft Dynamics NAV2013? Using Item Cross Reference allows you to quickly identify the items that were ordered by a customer or that you are purchasing from a vendor on the basis of item numbers other than your own. View this on ArcherPoint, Inc. > ——————————
Nigel Rhodes
Pacsafe
Seattle WA
Bob Bergman
MemberDecember 15, 2016 at 6:47 PM
Have you tried Rapidstart?
Bob Bergman
President
REB Dynamics Consulting
Port Charlotte FL
Saurabh Shah
MemberDecember 16, 2016 at 3:48 AM
As Bob mentioned, You should use RapidStart functionality of Dynamics NAV where you can import the data in bulk with all the validations of NAV.
Fort this requirement of Item Cross reference import, you should use Table 5717.
for more information about how to use the Rapidstart please follow below link:
https://msdn.microsoft.com/en-us/library/hh997463(v=nav.70).aspx
Let us know if you need any other help on this.
Saurabh Shah
Amerdian LLC
Midlothian VA
Jason Nicolaou
MemberDecember 16, 2016 at 7:55 AM
Which version are you on? NAV 2017 web client has an “Edit in Excel” function that allows publishing back to NAV easier than the traditional export → modify → import process.
Good luck and Happy Holidays!
Jason Nicolaou
Solutions Architect
Socius
Dublin OH
Rapid Start is probably the best way to go, but I will add if you don’t want to learn that, and aren’t using the Web Client, there is an Edit in Excel add-in for the Windows Client that can be installed. I personally don’t know that it’s worth adding a customization for something that you can do without one, but the option is there.
Matt Traxinger
NAV Developer
ArcherPoint Inc.
San Antonio TX
Eric Moe
MemberDecember 16, 2016 at 10:56 AM
You should be able to paste rows from Excel directly to the cross reference tables. You can right-click in the table and “Copy Rows”, then paste that into Excel to get the template. Fill out your information in Excel, select the data you want to add to NAV, copy, and then go back to the cross reference table, and right-click for “Paste Rows”. It should dump the data right in. Sometimes I have to delete the last row in the table to get the function to work.
Rapidstart, or “Configuration Packages” is another way to do pretty much the same thing.
Eric Moe
Business Analyst
Industrial Revolution
Tukwila WA
Rick Dill
MemberDecember 16, 2016 at 11:34 AM
Hi Nigel,
The process you referenced walks through the process to manually add records to the cross reference table.
If you are familiar with Rapid Start, (or data migration is it was referred to in pre-2015 releases), then you would be able to create an excel spreadsheet template, populate the 90 lines of data, and import them into the Item cross reference table.
NAV help walks you through the Rapid Start process so I will not cover that hear, but that would do exactly what you are looking for.
Rick Dill
Consultant
ArcherPoint Inc.
Waupaca WI
Kris Ruyeras
MemberDecember 16, 2016 at 5:12 PM
I will continue to hammer the nail here as others have noted, RapidStart would be the option to go, It would at least validate the Item no. as you import it and will let you know if there are any errors and that’s if you use NAV 13+ version.
Kristoffer Ruyeras
Bellegrove Medical Supply
Redmond, WA
Jeane Meade
MemberDecember 19, 2016 at 11:17 AM
I concur – RapidStart is the way to go. I am using RapidStart for this exact same process – putting in Item Cross References.
Jeane Meade
IT/DBM
Sheldons’, Inc.
Antigo WI
DSC Communities replied 8 years, 8 months ago 1 Member · 0 Replies -
The discussion ‘Uploading Multiple Item Cross References (instead of one at at time)’ is closed to new replies.
