Record Templates
Record Templates
Record Templates
Follow
Noreen Fujita-Sacco
Noreen Fujita-SaccoNov 03, 2022 07:43 PM
Hello, For NAV 2018, are the record Master Templates limited to Customer, Vendor, and Item cards? I’m …1. Record Templates
TOP CONTRIBUTOR
Noreen Fujita-Sacco
Posted Nov 03, 2022 07:43 PM
Hello,For NAV 2018, are the record Master Templates limited to Customer, Vendor, and Item cards? I’m particularly interested in setting up the Ship-to Address Cards with default field values.
If this is a NAV 2018 limitation, are additional records available to set templates in BC?
Thank you!
#NAV 2018
āāā——————————
Noreen Fujita-Sacco
Applications Coordinator
Coghlan’s/Gear Aid
Bellingham WA
360-392-2703
noreen.fujitasacco@gearaid.com
——————————2. RE: Record Templates
Brad Prendergast
Posted Nov 04, 2022 09:18 AM
Edited by Brad Prendergast Nov 04, 2022 09:18 AM
Templates are available for Customers, Vendors, Employees and Items. You could use configuration templates, but it would require a modification.——————————
—Thanks, and Best Regards,
Brad Prendergast
——————————3. RE: Record Templates
NAVUG ALL STAR
Posted Nov 04, 2022 09:56 AM
I’ve used templates for some other tables using the CREATE INSTANCE action in the ribbon on the template card.
This would be tricky and would probably require a modification for customer ship-to’s because the table has a multiple-field key (Customer Code + Ship-to Code).——————————
Mars Fishcare/Mars Horsecare
http://www.apifishcare.com
D365UG-BC/NAVUG All-Star
——————————4. RE: Record Templates
TOP CONTRIBUTOR
Noreen Fujita-Sacco
Posted Nov 04, 2022 12:06 PM
Thank you, all. It sounds unanimous that a customization is required even in BC. I appreciate your responses!——————————
Noreen Fujita-Sacco
Coghlan’s/Gear Aid
Bellingham WA
360-392-2703
[email protected]
The discussion ‘Record Templates’ is closed to new replies.
