NAV 2018 Lanham EDI 856 with Status Codes
  • Cliff McDaniel
    May 19, 2023 at 11:38 pm
    Let me see if I can find you an answer for this.
    May 20, 2023 at 11:16 am
    I am not familiar with Line Status codes on the ASN/EDI 856 What segment is that?
    If you are referring to the EDI855 (Purchase Order Acknowledgment), then you need to code it as E_SLSASN to use the status codes. I think that there is also an additional license requirement for the E_SLSASN. It may be the E_SLSPOA that is an export only document with no advanced functionality.
    There are some Lanham team members that read this board, so if I am incorrect on any of this, hopefully, they’ll correct me.
      May 20, 2023 at 1:02 pm
      <<If you are referring to the EDI855 (Purchase Order Acknowledgment), then you need to code it as E_SLSASN to use the status codes>>
      CORRECTION:
      If you are referring to the EDI855 (Purchase Order Acknowledgment), then you need to code it as E_ADVPOA to use the status codes
    • Noreen Fujita-Sacco
      May 22, 2023 at 7:51 pm
      Hi, Lewis.
      There can be status codes on an 856. This customer requires we send ASN as a final confirmation when shipped complete as well as notifying of a backordered item cancelling the entire order if any one item is not available. Status codes for 856 are in the same place as those for 855. Just choose a different EDI Doc No. and then enter codes for header and line as usual.
  • Ruthie-Moshos
    May 22, 2023 at 7:33 pm
    Hi, Noreen- I would need a little more information on what you are trying to do, but the 856 E_SLSASN does have a setup for status codes on the document itself. I’ll send you the documentation on this.
      May 22, 2023 at 7:57 pm
      Thanks, Ruthie.
      I did set codes up with defaults on both the Status Codes page and the 856 Export tab. however, I left Order Shipped and Item Shipped blank because we’re using Order/Item Shipped Complete and Order/Item Backorder Status Codes. Are those required and I should duplicate the Complete codes?
      Something else is wrong because NAV isn’t generating the BOL automatically. I’ll test again from a complete shipping station tomorrow and see if I get better alerts.
      So you’ve never used the E_SLSSTS for an 856?
        May 22, 2023 at 8:11 pm
        Oh, good grief. I set up the packing rule and somehow it wasn’t applied to the customer card. Mea culpa! Thank you all for your responses! I can continue testing.
  • Cliff McDaniel
    May 22, 2023 at 8:17 pm
    That’s great news Noreen. Thanks Ruthie for helping @ruthiemoshos
The discussion ‘NAV 2018 Lanham EDI 856 with Status Codes’ is closed to new replies.
