I believe there are still only 2 Global, 6 Shortcut, and unlimited dimensions in Nav 2017. Is this correct or has there been a change to the number of dimensions allowed from our current version (NAV 2009 R2 with Granule 4780 Advanced Dimensions) to NAV 2017?
—————————— Noreen Fujita-Sacco Applications Coordinator Gear Aid Inc. Bellingham WA 360-392-2703 noreen.fujitasacco@gearaid.com ——————————
James Davison
May 11, 2017 at 9:56 AM
Yes, out of the box it works the same way in the general ledger setup with assigning two global dimensions and the option for 6 more shortcut dimensions. Ā In general you can still create as many dimensions as you want and manually call them out on transactions/entries but in order for them to have their own column you would need to discuss customization with your partner but it can be done.
—————————— James Davison Admiral Consulting Group East Brunswick NJ —————————— ——————————————-
Geovanny Fuentes
May 11, 2017 at 6:36 PM
Some consultants never want to throw the word ENDLESS dimensions.
But you always had them viewable, reportable since the old versions of Navision.
Just NAV stills has the same thing 2 global are actual fields holding the values. The rest are quick temp visible fields (Shortcut 3,4,5,6,7,8) on the screen.Ā
You really want to take advantage of the reporting capabilities Navision has with the 2015, 2016 and 2017:
Analysis by Dimension Sales Analysis by Dimension Purch Analysis by Dimension See how Inventory is doingĀ
I like this file below because it has hyper links in the content areas. file:///C:/Users/gfuentes/Downloads/DynamicsNAV2017_CapabilityGuide_EN.pdf
