Distinguishing Companies
  • Distinguishing Companies
    Posted by Lars Anderson on November 10, 2017 at 12:53 pm
    • Lars Anderson
      November 10, 2017 at 12:53 PM
      We are operating multiple companies in two databases and want to make it very clear to our users which company they are in. Does anyone have any recommendations as to the best way to indicate on-screen, which company is being used, so it is unmistakable?
      All input gratefully received.
      Lars.
      Lars Anderson
      Phillip Jeffries
      Fairfield NJ
    • Kim Dallefeld
      November 10, 2017 at 1:07 PM
      In 2015, 2016 and 2017 you can change the company name to have a color around it. Check out Company Information and the System Indicator Style field. Changing this value from Standard to Accent# will change the background color around the company name. It’s a great visual and super handy!
      Kim Dallefeld
      VP Professional Services
      Syte Consulting Group
      kdallefeld@sytecg.com
      Past NAVUG Board Chairman
      NAVUG Programming Committee
    • Annette van der Muur
      November 13, 2017 at 3:55 AM
      ?These settings are also available in NAV2013R2.
      We use it the same way.
      Company + Database
      and a colour
      Hal Leonard
      The Netherlands
    • Meenakshi Singh
      November 13, 2017 at 7:59 AM
      Hi Lars!
      You also indicated different databases. Kim’s solution is great for multipleĀ companies within the same database but for multiple databases, you can create a different shortcut for each database.
      The color background for company’ name also works in 2013.
      Meenakshi
      Meenakshi Singh
      Home Market Foods, Inc.
      Norwood MA
    • Andrew Good
      November 13, 2017 at 8:01 AM
      The following is courtesy of Waldo’s Blog (NAV 2009 R2 System Indicator). It clearly shows the available colors.
      Accent1
      Accent2
      Accent3
      Accent4
      Accent5
      Accent6
      Accent7
      Accent8
      Accent9
      Andrew Good
      President
      Liberty Grove Software
      Oakbrook Terrace IL
    • Kim Dallefeld
      November 13, 2017 at 12:43 PM
      Thanks Andres, that’s a great list to have!
      Kim Dallefeld
    • Jason Nicolaou
      November 13, 2017 at 8:49 AM
      ?I am not a developer so I don’t know the effort required to make this happen, but changing the color scheme (the color of menu bars), like you can in Outlook, based on the company colors could be an option.Ā  To be clear, I am just suggesting if one logo is dominated by a certain color use that one, not that every feature/function is driven by multiple, new custom colors.Ā  A background color change may do it too.
      Jason Nicolaou
      Solutions Architect
      Socius
      Dublin OH
    Lars Anderson replied 7 years, 9 months ago 1 Member · 0 Replies
The discussion ‘Distinguishing Companies’ is closed to new replies.
