Why dax return first month as April and last month as September values??
  • Why dax return first month as April and last month as September values??
    Posted by DSC Communities on October 28, 2022 at 10:14 am
    • Raj Mh
      October 28, 2022 at 10:14 AM
      I have a simple table called date table and it returns or calculate values for month of April instead start of the month in data table as Nov.
      Also, for last month it return September instead of Oct.
      Is anyone had similar kind of issue?
      DAX:Ā
      >> start_dt =
      CALCULATEĀ (
      Ā Ā Ā Ā [TotalSales],
      Ā Ā Ā Ā FILTERĀ (Ā date,Ā date[MMYY].[Month]Ā =Ā MINĀ (Ā (Ā date[MMYY].[Month]Ā )Ā )Ā )
      >>end_dt =
      CALCULATE (
      [Totalsales],
      FILTER ( date, date[MMYY].[Month] = MAX ( ( date[MMYY].[Month] ) ) )
      Thanks for supportingĀ
      Raj
      Raj Mh
      Manager
    • Vilmar Santos
      October 28, 2022 at 10:30 PM
      OlĆ”
      Na expressão estÔ o nome do mês, altere para o número do mês.
      Se não der certo, envia o pbix, pode ser com dados fictícios.
      Vilmar Santos
    • Raj Mh
      October 31, 2022 at 7:30 AM
      Thanks Vilmar,
      Its not the case as data is correct. In my case there are product categories which may occurred as per sales transaction in any month and DAX shall pick the correct start and end date for that product category. To summarize below is the sample table and it shall pick dateĀ  and Sales value like:
      Product Name Start Month Sales End Month Sales
      Product100 Jan-21 100 Dec-21 100
      Product200 Jan-21 200 Dec-21 200
      Product300 Mar-21 300 Dec-21 300
      Sample table :
      Month Sales Product Name
      Jan-21 100 Product100
      Jan-21 200 Product200
      Feb-21 100 Product100
      Feb-21 200 Product200
      Mar-21 100 Product100
      Mar-21 200 Product200
      Mar-21 300 Product300
      Apr-21 100 Product100
      Apr-21 200 Product200
      Apr-21 300 Product300
      May-21 100 Product100
      May-21 200 Product200
      Jun-21 100 Product100
      Jun-21 200 Product200
      Jul-21 100 Product100
      Jul-21 200 Product200
      Aug-21 100 Product100
      Aug-21 200 Product200
      Sep-21 100 Product100
      Sep-21 200 Product200
      Oct-21 100 Product100
      Oct-21 200 Product200
      Nov-21 100 Product100
      Nov-21 200 Product200
      Dec-21 100 Product100
      Dec-21 200 Product200
      Dec-21 300 Product300
      Raj Mh
      Manager
    • Rd 3nidad
      November 1, 2022 at 1:20 PM
      Hi, I’m not sure what is wrong with your data but if you are just looking for the expected output as you mentioned, you can use helper columns in the dataset such as rank ascending and / or descending. Consider the sample report attached.
      Rd 3nidad
      Senior Finance Analyst
    • Raj Mh
      November 4, 2022 at 9:27 AM
      thanks it work as expected
      Thanks to others as well who all supported in this thread!?
      Raj Mh
      Manager
    • Kaz Shakir
      October 31, 2022 at 12:32 PM
      In your formulas you are taking the MIN and MAX of the field called date[MMYY].[Month].Ā  Can you tell us the data type for that field?Ā  Is it a number, or is it text, or is it a date?Ā  In other words would it have a value of 1, 2, 3 for Jan, Feb, Mar? or would it have the values of “Jan”, “Feb”, “Mar”?
      Kaz.?
      Kaz Shakir
      TN
    • Raj Mh
      November 1, 2022 at 1:28 AM
      Hello Kaz,
      Data type for Month column is ‘Date’ and its not value like 1-21 instead its Jan-21
      Raj Mh
      Manager
    • Adam Artur Boltryk
      November 1, 2022 at 3:29 PM
      Hi Raj,
      Hard to say without full view of your model.
      It can be:
      1. Filter context from page.
      2. Year can be set on Fiscal Year.
      3. as TODAY is 1st day of the new month, data and model are not submitted/refreshed yet.
      4. a few more reasons.
      Adam Artur Boltryk
      Business Analyst
    • Tomas Torp
      November 1, 2022 at 4:10 PM
      Hi Raj,
      As long as you do not turn off auto date/time in the settings, a hidden date table will be generated for each date column in the model, so while date[MMYY] might be of data type date, the column date[MMYY].[month] in the hidden date table is of data type text. Therefore, April is the minimum month and September is the maximum month.
      One way to fix this is to use the MONTH function instead, but keep in mind that this will only make sense as long as you look at one year at a time:
      >> start_dt =
      CALCULATE (
          [TotalSales],
          FILTER ( date, MONTH ( date[MMYY] ) = MONTH ( MIN ( date[MMYY] ) ) )
      >> end_dt =
      CALCULATE (
          [TotalSales],
          FILTER ( date, MONTH ( date[MMYY] ) = MONTH ( MAX ( date[MMYY] ) ) )
      Tomas
The discussion ‘Why dax return first month as April and last month as September values??’ is closed to new replies.
