Based on the below data, I want the report to show:
FILTER 1: where the count of products > 1 for the regions Ā
FILTER 2: also show product “DDD” (even though the count is 1 as it is just in 1 region)
ProductID
Name
Region
Sales
AAA
Product A
US
10,000
BBB
Product B
CAN
20,000
BBB
Product B
US
30,000
CCC
Product C
US
40,000
DDD
Product D
EU
15,000
AAA
product A
EU
10,000
AAA
Product A
CAN
10,000
EEE
Product E
US
10,000
So the report should show:
Products
Count
AAA
3
BBB
2
DDD
1
Also, the second filter can change from time to time, so would like the user to have the ability to include / exclude products as needed. For example: currently, they have included “DDD” but they might want to include “XYZ” later.
I tried adding the count in the filter panel where COUNT is Greater than 1 . This works but does not show “DDD” .Ā
How can I achieve this kind of filtering?
—————————— Bijal Patel ——————————
Lutz Bendlin
March 27, 2020 at 4:26 PM
In your measure definition you can use logic operators like “&&”Ā (and)Ā and “||”Ā (or) to model these conditions.Ā There’s also the OR() DAX function.
Thanks Lutz! I am new to Power BI and I can’t get to code the below logic in a measure.Ā
Can you provide me with a sample measure for the below condition?Ā
If count(product) > 1 Ā Ā Ā Ā Ā Ā display count Ā Ā else Ā Ā Ā Ā Ā ifĀ product = “DDD”Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā displayĀ countĀ Ā Ā Ā Ā Ā end if end if
—————————— Bijal Patel —————————— ——————————————-
Lutz Bendlin
March 27, 2020 at 11:50 PM
As always there are many ways to do that.
The option with logic operators: Var x = if(count(product)>1 || product =”DDD”,count,blank())
If you don’t want to to write nested IF statements you can use the syntax sugar SWITCH(): Var x = switch(true(),count(product)>1,count,product = “DDD”,count,blank())
I was able to achieve what I wanted by: 1) creating a measure to return the count of the products that I wanted to include (in this case “DDD”) – had to do this as I wasn’t able to reference the column in the IF condition in the measure directly. So couldn’t do:Ā product = “DDD”.Ā 2) Then created a measure with the IF condition : where count(product)> 1 || [Measure created in Step 1]
May be you can combine both the measures but in my case had to keep them separate as I plan on using the first measure in other parts of report.
