Values abnormal at 12:00 AM
  • Values abnormal at 12:00 AM
    Posted by DSC Communities on May 17, 2021 at 3:03 am
    • Asif Dakhway
      May 17, 2021 at 3:03 AM
      I’m trying to make report with hourly data pulling from MS SQL database, If I prepare it in Powerbi Desktop it shows correct value but if I publish same report to Powerbi it shows abnormal value. Can anyone help me
      Snapshot from Power bi Desktop application
      Snapshot from Power bi website
      Asif Dakhway
    • Asif Dakhway
      May 17, 2021 at 3:45 AM
      My DateTime fieldsĀ
      Asif Dakhway
    • Ben Howard
      May 17, 2021 at 6:16 AM
      Are you able to share your .pbix file?
      Ben Howard, UK.
      Please mark any answer as recommended if it helps you.
    • Bill Kellam
      May 18, 2021 at 6:55 AM
      Is it possible you are looking at another report from the same dataset? Check the lineage of the dataset.
      Bill Kellam
    • Asif Dakhway
      May 27, 2021 at 2:54 PM
      I cannot share the data. lineage is OK
      Asif Dakhway
    • Vishesh Jain
      June 7, 2021 at 4:36 AM
      Hi ,
      Can you please check that the dates are being read correctly on PBI Service as I have faced a similar problem and my numbers go haywire.
      Instead of a graph try putting the measures on a table with the date and time, this way you can investigate what is actually going on with? the numbers.
      I say this because if you look at the Y-axis the numbers are nearly double of what you have on the desktop.
      Thank you,
      Vishesh Jain
      MCSA Power BI and Excel
      Emerald Award Dynamic Communities 2019
      Owner
      VR Construction
    • Asif Dakhway
      June 8, 2021 at 4:07 AM
      Thanks Vishesh,
      I’ll check this and one thing I want to add is I’m using incremental refresh
      Asif Dakhway
    • Vishesh Jain
      June 8, 2021 at 8:21 AM
      Hi ?,
      Incremental refresh should not affect this, as it is only related to data refreshes.
      My assumption is, that the dates are being read wrong, which is why the numbers are changing and in effect the Y-axis scale too.
      Investigate the actual numbers first as this will show if and when, what is wrong where.
      Thank you,
      Vishesh Jain
      Owner
      VR Construction
    • Asif Dakhway
      June 10, 2021 at 4:27 AM
      I found something strange, I tried report by disabling Incremental refresh, then after publishing to PBI service and refresh from PBI service it shows fine no abnormality
      then I enabled the Incremental refresh and after publishing to PBI service and refresh from PBI service it shows again abnormality.
      My table is getting updated every hour below is the snap of my incremental refresh
      I tried with enabling Detect data changes and Only refresh complete days also but same result
      Asif Dakhway
    • Asif Dakhway
      June 10, 2021 at 4:37 AM
      One more thingĀ
      In both the scenario after publishing report on PBI service it shows normal
      It is getting abnormal only when I refresh from PBI service ( After enabling incremental refresh)
      Asif Dakhway
    • Asif Dakhway
      June 13, 2021 at 7:41 AM
      I found the problem
      Actually while filtering the dattimeĀ  column instead of selecting “is before” I wasĀ  selecting “is before or equal to” for RangeEnd option
      after correcting, it works fine
      Thanks for everybody
      Asif Dakhway
    DSC Communities replied 4 years, 7 months ago 1 Member · 0 Replies
The discussion ‘Values abnormal at 12:00 AM’ is closed to new replies.
