Hello, I am trying to Patch a single record in the Orders table in SQL.Ā There is an Orders gallery and the gallery consist of an OrderID, CustomerName, SalesRep, Picked, CompletedDate.Ā I would like to have a date picker field in the CompletedDate column and a check box for the PIcked column so that it is an edit in the gallery.Ā I cannot get my Patch command to work when I update either field.Ā Each column is independent of the other column and only one can be selected at a time and the CompletedDate can not be selected until the Picked column is completed.Ā The system keeps giving an error the Record cannot be found.Ā
I can get it to work using a form to be displayed over the gallery and using the SubmitForm(frmComletedDate) or SubmitForm(frmPicked) then selecting the save button.Ā I was trying to get away from using the form.
Thank you in advance for your help. Kind regards, John
Thanks for the information. That is exactly what I had tried. It seems to be working now a day later, closed the app and then opened it the next day and it is working.
