I have a large OLAP cube, that I am looking to dynamically filter data on prior to loading into Power BI.
I want users to have the option of entering 1 or multiple items in the filter. To solve this, I created a parameter where users can enter comma delimited values. I then take this parameter and do the following using M and MDX:
1. Generate a list from the parameter string (Text.Split(myParameter,”,”)
2. Create the necessary MDX text surrounding parameter values to add as a filter.
3. Store the result in a string.
I then take the result string and add it to the query string at the correct area. If I create this string outside the query and enter the literal information everything works fine. If I use the string variable, I get the following error:
DataSource.Error: An error happened while reading data from the provider: ‘Object reference not set to an instance of an object.’ SQL Server OLAP
Is there a limitation for using M language in a Native Query when using OLAP, and if so, is there a workaround that will not be too painful to the end user?
—————————— Peter Globus ——————————
Peter Globus
January 23, 2018 at 5:04 PM
After further testing, I confirmed the error I am seeing is unrelated to the string and OLAP. The actual cause is that no rows are returning for the items I initially included. Lesson learned. š
—————————— Peter Globus —————————— ——————————————-
Audrey Abbey
January 23, 2018 at 7:31 PM
Lesson SHARED and that is what is important.Ā
Error messages are so vague, lol.
—————————— Audrey Abbey SR. BI Developer/Analyst New Seasons Market Portland OR —————————— ——————————————-
