Token Eof expected (row #1)
Posted by DSC Communities on December 1, 2019 at 12:37 pm-
GƩrard Ducouret
MemberDecember 1, 2019 at 12:37 PM
I’m trying to create my first Function. In fact I use the Applied steps list and the Advanced Editor.Ā
I just added 2Ā rows at the beginning and 2 at the end.Ā
I always get an error : “Token Eof expected” with a red symbol on the first row
What I did wrong ? š
ThanksPLease see attached txt file
GƩrard Ducouret
Audrey Abbey
MemberDecember 1, 2019 at 11:19 PM
Hi Gerard,Try changing your capital letters in “Let” and “In: to lower case.
Power Query is case sensitive and the commands should be all lower case.
You may also need to add the data type to your parameter “NomFichier“
Here is an example of a function I have in one of my files, that calls a stored procedure with Start and End date parameters, so that you can see the syntax.
I set up the StartDate and EndDate parameters before setting up the function.let
SQLSource = (StartDate as date, EndDate as date) =>let
Source = Sql.Database(“ServerName”, “DatabaseName”, [Query=”EXEC Database.dbo.StoredProcedureName ‘”&Date.ToText(StartDate)&”‘,'” & Date.ToText(EndDate)&”‘”, CreateNavigationProperties=false])
in
Source
in
SQLSourceHope that helps!
Audrey Abbey
SR. BI Developer/Analyst
LeapFrogBI
Portland OR
GƩrard Ducouret
MemberDecember 2, 2019 at 8:26 AM
Great! That works!
Thanks a lot Audrey——————————
GƩrard Ducouret
Farhan Ahmed
MemberDecember 2, 2019 at 12:19 AM
Yes you need need to change “Let” and “In” to small case as mentioned,Ā Power Query is case sensitivelet Recup = (NomFichier) => let Source = Excel.Workbook(File.Contents(NomFichier), null, true), Feuil1_Sheet = Source{[Item="Feuil1",Kind="Sheet"]}[Data], #"Promoted Headers" = Table.PromoteHeaders(Feuil1_Sheet, [PromoteAllScalars=true]), #"Removed Top Rows" = Table.Skip(#"Promoted Headers",38), #"Filled Down" = Table.FillDown(#"Removed Top Rows",{"Column1", "Column2", "Column3"}), #"Filtered Rows" = Table.SelectRows(#"Filled Down", each [DonnĆ©es en 7 classeurs Excel] <> null), #"Filtered Rows1" = Table.SelectRows(#"Filtered Rows", each [DonnĆ©es en 7 classeurs Excel] <> "Total"), #"Promoted Headers1" = Table.PromoteHeaders(#"Filtered Rows1", [PromoteAllScalars=true]), #"Changed Type" = Table.TransformColumnTypes(#"Promoted Headers1",{{"Marque ", type text}, {"AnnĆ©e", type text}, {"Version", type text}, {"Pays", type text}, {"01", Int64.Type}, {"02", Int64.Type}, {"03", Int64.Type}, {"04", Int64.Type}, {"05", Int64.Type}, {"06", Int64.Type}, {"07", Int64.Type}, {"08", Int64.Type}, {"09", Int64.Type}, {"10", Int64.Type}, {"11", Int64.Type}, {"12", Int64.Type}}), #"Unpivoted Other Columns" = Table.UnpivotOtherColumns(#"Changed Type", {"Marque ", "AnnĆ©e", "Version", "Pays"}, "Attribute", "Value"), #"Added Custom" = Table.AddColumn(#"Unpivoted Other Columns", "Date", each "01"&"/"&[Attribute]&"/"&[AnnĆ©e]), #"Changed Type1" = Table.TransformColumnTypes(#"Added Custom",{{"Date", type date}}), #"Removed Columns" = Table.RemoveColumns(#"Changed Type1",{"AnnĆ©e", "Attribute"}), #"Filtered Rows2" = Table.SelectRows(#"Removed Columns", each [Value] <> 0) in #"Filtered Rows2" in Recup?
Farhan Ahmed
Senior Business Intelligence Consultant
karachi
3452523688
DSC Communities replied 5 years, 9 months ago 1 Member · 0 Replies -
The discussion ‘Token Eof expected (row #1)’ is closed to new replies.
