The Web.Page function requires Active Scripting to be enabled in Internet Explorer options
  • The Web.Page function requires Active Scripting to be enabled in Internet Explorer options
    Posted by DSC Communities on January 15, 2019 at 1:00 am
    • Piotr Michalak
      January 15, 2019 at 1:00 AM
      Hello
      I can’t find solution for “The Web.Page function requires Active Scripting to be enabled in Internet Explorer options….” error which appear when i want to refresh dataset on PBI site using gateway
      I have two env – both Virtuall Machines one Azure,  second AWS – the same windows version
      In Azure i don;t have any errors, on AWS machine
      Swallowing exception during Ado query execution attempt and triggering a retry: Microsoft.Data.Mashup.MashupValueException (0x80004005): The Web.Page function requires Active Scripting to be enabled in Internet Explorer options. See https://go.microsoft.com/fwlink/?LinkId=506565 for details on how to enable Active Scripting.
         at Microsoft.Data.Mashup.ProviderCommon.MashupResource.<>c__DisplayClass4`1.<StartEvaluationAndGetResultSource>b__2()
         at Microsoft.Mashup.Security.Impersonation.RunAsProcessUser[T](Func`1 func)
         at Microsoft.Data.Mashup.MashupCommand.EvaluateAndGetSource[T](String commandText, CommandType commandType, Int32 commandTimeout, MashupParameterCollection parameters, String resultTransform, Boolean forColumnInfo, Boolean executeAction)
         at Microsoft.Data.Mashup.MashupCommand.ExecuteReader(CommandBehavior commandBehavior, MashupCommandBehavior mashupCommandBehavior)
         at Microsoft.PowerBI.DataMovement.Pipeline.MashupCommon.MashupUtils.ExecuteReaderAsync(DbCommand command, ExecuteQueryRequest queryRequest)
         at Microsoft.PowerBI.DataMovement.Pipeline.GatewayCore.GatewayProcessor.<>c__DisplayClass3_2.<<ExecuteAdoQuery>b__1>d.MoveNext()
      — End of stack trace from previous location where exception was thrown —
         at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
         at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
         at Microsoft.PowerBI.DataMovement.Pipeline.Common.Diagnostics.PipelineTelemetryService.<ExecuteInActivity>d__7`1.MoveNext()
         at Microsoft.PowerBI.DataMovement.Pipeline.GatewayCore.GatewayProcessor.<>c__DisplayClass3_0.<<ExecuteAdoQuery>b__0>d.MoveNext()
      IE options are the same.
    • Christian Harrington
      April 8, 2019 at 12:18 PM
      did you find the solution for this. We had the same issue here and this post was very helpful:
      https://community.powerbi.com/t5/Developer/The-Web-Page-function-requires-Active-Scripting-to-be-enabled-in/m-p/631071
      This is what we did and it worked! So I am sharing with you in case you are still looking for it:
      * From the Windows Server Start menu (on the Gateway server), open the Local Group Policy Editor (gpedit.msc).
      * Under Local Computer Policy, expand Computer Configuration > Administrative Templates > Windows Components > Internet Explorer > Internet Control Panel > Security Page > Internet Zone.
      * Right-click Allow active scripting and click Edit.
      * In the Allow active scripting dialog, click Enabled.
      * In the Options area, select Enable from the list.
      Christian
      BI Specialist
      Boucherville QC
      5148313734
The discussion ‘The Web.Page function requires Active Scripting to be enabled in Internet Explorer options’ is closed to new replies.
