Sum of MAX
  • Sum of MAX
    Posted by DSC Communities on May 11, 2022 at 10:11 am
    • SAHLER Marine
      May 11, 2022 at 10:11 AM
      SOLVED :
      Hi Everyone, I’m new here…Ā
      My problem is quite simple :
      I would like a Sum of Max passengers on bord for a Class and a Date… It’s OK with the following formula, but it cannot calculate the sum for one flight !! It give me the MAX of the class it find…Ā
      Formula :
      NB_PAX = CALCULATE (MAX(Conso_CatSpec[Pax] ), DISTINCT(Conso_CatSpec[Flight]), DISTINCT(Conso_CatSpec[Dep.Date]))
      See attached files for an exempleĀ
      Many thanks for your help šŸ™‚Ā
      Marine
      SAHLER Marine
    • Olivier Aillery
      May 12, 2022 at 3:24 AM
      You will need the SUMX function to compute every row of your data, so it should be something like :
      Sum of MAX = SUMX( VALUES( [Class] ), CALCULATE( ALL( [Flights] ) , MAX ([Nb PAX]) ) )
      Class = Eco, premium…
      Flights = AF650YRGML
      NB Pax your measure counting pax
      Hope it helps
      Olivier
    • SAHLER Marine
      May 12, 2022 at 8:35 AM
      Hi Olivier,
      And thanks for your response.Ā
      I’ve tried your solution but it says “A function MAX has been used in a True/False expression that is used as a table filter expression. This is not allowed.”
      If it can help, I attached an exemple of my table.Ā
      Thanks again,
      Marine
      SAHLER Marine
    • SAHLER Marine
      May 12, 2022 at 10:48 AM
      I found something : By mixing your solution with mine, it works !
      Merci šŸ™‚
      NB_PAX_Class = SUMX( VALUES( Class[Class GƩnƩ]), CALCULATE (MAX(Conso_CatSpec[Pax] ), DISTINCT(Conso_CatSpec[Flight]), DISTINCT(Conso_CatSpec[Dep.Date])))
      Many thanks,
      Marine
      SAHLER Marine
    • Olivier Aillery
      May 12, 2022 at 12:11 PM
      De rien Marine et merci d’avoir partager la solution šŸ™‚
      Olivier
    DSC Communities replied 3 years, 10 months ago 1 Member · 0 Replies
The discussion ‘Sum of MAX’ is closed to new replies.
