Sql Server Permissions
  • Sql Server Permissions
    Posted by sam-duval on June 25, 2020 at 11:05 pm
    • Sam Duval
      June 25, 2020 at 11:05 PM
      Not really a power bi question, but hoping the collective Brain power here can help me.
      I’m trying to add users of a department of my company call it “reporter” as a user on the azure sql Server.Ā
      I’ve created a user that’s mapped to their ad group and mapped that to a database role that has permissions select, execute, insert in a schema called reporter.
      I create a view in the server called reporter.sales which for simplicity is this code:Ā
      Select * from dbo.master_sales
      When someone from the reporter department trys to run a paginated report using their oauth, they are getting an error message that says they don’t have permission to read dbo.master sales.
      I’ve done this before with other departments so I know it can be done, but I can’t figure out what I did differently with the others.
      Thanks all
      Sam Duval
      Data Quality Analyst
      Element Financial
      Indianapolis IN
    • Sean Graham
      June 26, 2020 at 3:12 AM
      Hi Sam,
      Ā  Ā Ā  Yep, not really a Power BI question šŸ™‚Ā
      Ā  Ā Ā  But is it a case that you are only giving permission to the view and not the underlying objects that the view references like the dbo.master_sales?
      Ā  Ā Ā  Also I think that select permission is all that is needed.
      Sean
      Sean Graham
      BI Consultant
      Dublin
    • Riccardo Perico
      June 26, 2020 at 3:51 AM
      Is the underlying table in a different database?
      Riccardo Perico
      Data Platform & BI Specialist
      SolidQ Global
    • Sam Duval
      June 26, 2020 at 6:57 AM
      It’s the same database, an external table, but same database.
      I’ll double check but the others I’ve setup don’t have select access to the underlying table directly. I’m trying to prevent them from writing a swl script to query underlying tables. It’s a rudamentry security check. That they only have access to the data exposed in their schemas, they can’t back door their way to the whole database. We got dinged for that in our old system during an audit.
      Sam Duval
      Element Financial
      Indianapolis IN
    • Sam Duval
      June 27, 2020 at 8:42 PM
      Closing the loop here in case someone stumbles upon this post. The issues was the schema owner has to be the same schema as the underlying table. so in order to query dbo.tablex from sales.tablex_view schema sales has to be owned by dbo
      Sam Duval
      Element Financial
      Indianapolis IN
    sam-duval replied 5 years, 2 months ago 1 Member · 0 Replies
The discussion ‘Sql Server Permissions’ is closed to new replies.
