Sending a POST API request using PowerQuery on Excel/PBI with a request body?
  • Sending a POST API request using PowerQuery on Excel/PBI with a request body?
    Posted by DSC Communities on September 12, 2022 at 4:40 pm
    Sending a POST API request using PowerQuery on Excel/PBI with a request body?Follow
    Chase S
    Chase SSep 12, 2022 06:13 PM
    I am attempting to send a POST request using an API in PowerQuery on Excel/PBI. The request requires …
    1. Sending a POST API request using PowerQuery on Excel/PBI with a request body?
    Chase S
    Posted Sep 12, 2022 06:13 PM
    I am attempting to send a POST request using an API in PowerQuery on Excel/PBI. The request requires a body, and I’ve tried a few different ways (see below) but I keep receiving a DataSource.Error: Web.Contents failed to get contents from ‘https://myapi.com/data’ (400): Bad Request.
    My request looks like this (tried two different ways):
    let
    Source = Json.Document(Web.Contents(“https://myapi.com/data”, [Headers=[#”X-Impersonate-User”=”usr_12345″, Authorization=”Bearer tok_12345″, #”Content-Type”=”application/json”],
    Content=Json.FromValue({[start_date=”2022-08-01T08:00:00.000Z”, end_date=”2022-08-10T08:00:00.000Z”, space_ids=”spc_12345″, time_resolution=”day”]})
    in
    Source
    let
    url = “https://myapi.com/data”
    body = “{“”start_date”” : “”2022-08-01T08:00:00.000Z””, “”end_date”” : “”2022-08-10T08:00:00.000Z””, “”space_ids”” : “”spc_12345″”, “”time_resolution”” : “”day””}”,
    Parsed_JSON = Json.Document(body),
    BuildQueryString = Uri.BuildQueryString(Parsed_JSON),
    Source = Json.Document(Web.Contents(url,[Headers=[#”Content-Type”=”application/json”, #”X-Impersonate-User”=”usr_12345″, Authorization=”Bearer Bearer tok_12345″], Content = Text.ToBinary(BuildQueryString) ] ))
    in
    Source
    I have no problems calling the API from postman… so can’t figure out what’s going on here.
    Chase S
    2. RE: Sending a POST API request using PowerQuery on Excel/PBI with a request body?
    Kaz Shakir
    Posted Sep 12, 2022 06:55 PM
    @Chase S,
    Saw this on another site – let us know if it works for you:
    Kaz.​
    Kaz Shakir
    TN
    3. RE: Sending a POST API request using PowerQuery on Excel/PBI with a request body?
    Chase S
    Posted Sep 13, 2022 09:59 AM
    No luck there. Getting the same (400): Bad Request.
    Chase S
    4. RE: Sending a POST API request using PowerQuery on Excel/PBI with a request body?
    Bronze Contributor
    James Watts
    Posted Sep 13, 2022 02:40 AM
    Do you need to do a call previously with uname/password to get the Bearer token with this site ?
    James Watts
    Business Intelligence Analyst
    5. RE: Sending a POST API request using PowerQuery on Excel/PBI with a request body?
    Chase S
    Posted Sep 13, 2022 10:00 AM
    I get the Bearer token directly (I know what it is per client and use that).
    Chase S
    6. RE: Sending a POST API request using PowerQuery on Excel/PBI with a request body?
    Kaz Shakir
    Posted Sep 14, 2022 06:44 PM
    @Chase S,
    I tried the following as a test, and seems to work.
    Here is the query that I created:
    let
    body = “{ “”TestItem””: “”This is one””, “”NextItem””: “”Another””}”,
    Data = Web.Contents(“https://httpbin.org/post”, [Content=Text.ToBinary(body), Headers=[#”Content-Type”=”application/json”]]),
    DataRecord = Json.Document(Data),
    Source = DataRecord[data]
    in
    Source​
    ​As you can see the body is simply a JSON object that contains two attributes. This particular endpoint, https://httpbin.org/post, accepts only post requests, and simply echoes back whatever payload you send it. It’s used for testing your code (you can learn more about the site by going to https://httpbin.org ). When I let this code execute, I get the following:
    And if you look at the result of the previous step in the query, it looks like this:
    Perhaps you could try this with your own endpoint and payload.
    Hope that’s helpful.
    Kaz.
    Kaz Shakir
    TN
    replied 2 years, 6 months ago 1 Member · 0 Replies
The discussion ‘Sending a POST API request using PowerQuery on Excel/PBI with a request body?’ is closed to new replies.
