Hi All, i have question to select a day in a month. I have 12 months data and I want to select only last Thursday of the month by DAX. Is it possible?
—————————— Krishna Nandan SME Bangalore ——————————
Lutz Bendlin
June 17, 2020 at 1:51 PM
Define “select”.Ā Do you want a calculated column in your dates table with that flag, do you want a measure, or do you just want to have a list of months and then the date for that thursday?
Here’s an example of the latter, based on a calculated column (assuming you have no other filters that could impact that, like “Last thusday of each month that we have transactions for”Ā etc)
Hi Lutz Thank you very much for your reply. i will give you the context- i have a multi row card and what i have to do is, if i select a month in the slicer multi row card should show two months comparison. For this i wrote a parameter and sync with card calculation measure .Ā
Below formula i use for that. Dynamic BACKup succ =
Now the issue is- i have one table where i have to take only last ThursdayĀ data for the month which will be a measure column and i can use the same slicer from that.Ā Also, i did not understand your code- My DAX is not taking Dates[monthcode] and what is month code here?
thanks krishna
—————————— Krishna Nandan SME Bangalore —————————— ——————————————-
