I think I am facing a limitation of PowerBI. I have a dataset in my workspace on which there is RLS
Everything is fine if I do a simple report to put all the presentation part, connected to this dataset. The RLS is working well.
On the other hand, if I make a report connected to this dataset, but which also has its own dataset in import mode (and therefore the report switches to mixed mode) with a link between the 2, I lose the right to ‘display the data that is in the cube with RLS.
Having been on the problem for 2 week, I decided to simplify it and go with an very simple model: (No measurement or DAX request)
Step 1 : Creation of a TEST_RLS.pbix report which contains the data (1 simple table with 2 columns: cli and user) and the RLS rule: Creation of a TEST_ROLE role and the following DAX formula on the user column: [user] = username ()
2nd step : Publication on the service and assignment of users in TEST_ROLE Connection test with a user who is not admin and who is in the list. => OK The data is well filtered.
Step 3: Creation of a DATA_VIEW report, Connected to the TEST_RLS dataset Display of a table that reads the data from the table of the TEST_RLS report The connection mode is therefore DirectQuery Publication, share to user Connection with the user who has the rights => OK The data is well filtered
Step 4: Import of an Excel file locally in the DATA_VIEW report (Without even creating a link between the 2 datasets) Suddenly, it switches to MIXED storage mode Publication Connection with the same user …. And there, impossible to display the data coming from TEST_RLS “Unable to display visual element” message on my board
However, as Admin, everything is displayed of course.
Thank you in advance for your help
—————————— Franck Servant-Roumey
Geron Meeks
April 20, 2021 at 3:27 PM
We have been experiencing the same issue.Ā I just discovered that you apparently need to “Add Build” to View access in Mixed Mode datasets.Ā We added that to both all datasets and it appears that has solved our problem.Ā Ā
