i have some questions over install and use a data gateway
i have a sql server on a securised server , and i want install on it a gateway thrughĀ powerbiGatewayInstall.exe , but i have some error during installation it seems to be trouble over not opent portĀ ( last error is overĀ 127.0.0.1:45375Ā )Ā Ā
have you the list of port to open when we install a powerbi gateway
and my last question :
after creating the gateway, i can find it on my workspace on the powerbi portal.Ā after creating dataset on this gateway and creating powerbi report.Ā how share this powerbi report with other user, this report using this gateway .
Is the gateway and dataset automatically embedeed and install on the destination user when i share the report ?
or i need to do some operation to share the gateway ?
In relation to Reports in PBI Service that use the Gateway to get Data…Ā the PBI Report resides only within your organisations Tenancy.Ā When you share a report, that user access the exact same report as you.Ā
regards,
—————————— Neville Howard Consultant Brisbane 0732228400 —————————— ——————————————-
Lutz Bendlin
March 2, 2020 at 7:41 AM
There is a difference between a personal and on-premise Enterprise gateway – which one are you trying to install?
When an on-premise gateway connection is created you have to specify the credentials that are used for that connection.Ā After that any dataset that uses the gateway for refreshes (and any developer that you have given permission to use it) will use these credentials. This may or may not be appropriate for your security requirements.
