PowerApps Connections and Sharing the Application
  • PowerApps Connections and Sharing the Application
    Posted by Sandra Gregory on May 8, 2020 at 6:00 pm
    • Sandra Gregory
      May 8, 2020 at 6:00 PM
      I developed a pretty elaborate PowerApps application… Using SQL on-Prem, SharePoint, Business OneDrive, PowerAutomate (Flow), etc.
      I am having a couple of issues:
      1.) I shared the application and all of the connections along with the PowerAutomate (Flow) to another user. All of the connections I shared they have but when they open the application (only through the developer’s link) it does not connect the data sources to the database even though they have the connect. Why is it doing this? The only way we can think of is to delete the data sources and re-connection them all with the other user but that doesn’t work since we are sharing the application. PLEASE HELP!!!
      2.) I can only access it through the developer’s link https://us.create.powerapps.com and cannot access it through user’s link to play the application https://apps.powerapps.com/play/ … and I don’t understand why?
      3.) I have extra connections that it ask for each time I open the application for SQL Server and OneDrive for Business keep popping up and it won’t go away even though I’m not using these. If I click the button DON’T ALLOW it allows me into the application just fine. How do I get rid of this?
      Thank you!!!Ā
      Sandra Gregory
      Sr. Business Analytist
    • Warren Belz
      May 13, 2020 at 3:43 AM
      Hi Sandra,
      This is a stab in the dark, but it cannot hurt anything.
      Try the Export Package and see if the connections are listed in Related Resources. If not, you should be able to import the package without themĀ  or re-create them if necessary.
      Warren Belz
      Rockhampton Qld Australia
      +61 409 315 509
    Sandra Gregory replied 5 years, 4 months ago 1 Member · 0 Replies
The discussion ‘PowerApps Connections and Sharing the Application’ is closed to new replies.
