Power BI PowerShell Cmdlets
  • Power BI PowerShell Cmdlets
    Posted by DSC Communities on May 21, 2019 at 7:20 pm
    • Ben Oastler
      May 21, 2019 at 7:20 PM
      Hi everyone,
      Can you assign Premium Capacity to a Workspace using PowerShell?
      Can you create App Workspaces using PowerShell?
      Can you assign a PowerBI Pro licence via PowerShell?
      Can you check if a user has a PowerBI Pro licence with PowerShell?
      Can you check to see if a Workspace has premium Capacity with PowerShell?
      thanks
      Ben
      Ben Oastler
      Practise Director – North America
      Bizdata
      +1 (917) 724 1666
      ben.oastler@bizdata.com.au
    • Tuhin Tapadar
      May 22, 2019 at 3:38 AM
      Hi Ben,
      Although, I am not a champion on PowerShell on Power BI but these two websites definitely help you with your queries.Ā Ā
      Working with PowerShell in Power BI | Microsoft Power BI Blog | Microsoft Power BI
      Microsoft remove preview
      If you are following the Power BI blog on a regular basis, you probably have noticed the Power BI APIs and cmdlets announcement for administrators, which introduced a set of APIs and cmdlets to work…
      View this on Microsoft >
      https://powerbi.microsoft.com/en-us/blog/working-with-powershell-in-power-bi/Ā
      https://insightsquest.com/2018/12/24/power-bi-workspace-scripts/Ā
      Tuhin Tapadar
      Data Analyst
      Dublin
      894164048
    • Lutz Bendlin
      May 22, 2019 at 7:20 AM
      Full reference is here
      https://docs.microsoft.com/en-us/powershell/power-bi/overview?view=powerbi-ps
      Lutz
    • Mike Anderson
      May 22, 2019 at 9:20 AM
      In short, I believe the answers are as follows:
      Yes, I believe this can be done based on the API –Ā https://docs.microsoft.com/en-us/rest/api/power-bi/capacities/groups_assigntocapacity
      No, I see no REST API that can do this, only retrieve existing apps – Apps (Power BI Power BI REST APIs)
      Yes, this should be possible but you’d have to call into Office 365 API’s I’m assuming, something like this?Ā Ā Using Power BI Audit Log and PowerShell to assign Power BI Pro licenses | Microsoft Power BI Blog | Microsoft Power BI
      I believe the above might be able to accomplish this.
      Yes, I believe based on this API –Ā Groups – Get Groups (Power BI Power BI REST APIs)
      You could then use the PowerShell CMDLETS the previous users mentioned to call the Power BI REST API’s with the Invoke-PowerBIRestMethod –Ā Invoke-PowerBIRestMethod (MicrosoftPowerBIMgmt.Profile).
      It may be the PS CMDLETS can do this, at quick glance I didn’t see the option for capacity assignment but might have missed it.
      Cheers,
      Mike Anderson
    • Ben Oastler
      May 22, 2019 at 4:16 PM
      Thanks Mike, that’s perfect!
      Ben Oastler
      Bizdata
      eastwood
      +1 (917) 724 1666
    DSC Communities replied 6 years, 3 months ago 1 Member · 0 Replies
The discussion ‘Power BI PowerShell Cmdlets’ is closed to new replies.
