Power BI Dataset
  • Power BI Dataset
    Posted by sam-duval on September 10, 2019 at 9:23 am
    • Sam Duval
      September 10, 2019 at 9:23 AM
      Is it possible to create a data set with either PBI dataset or from within paginated report builder that can be at the database level and shared? I just got paginated report builder installed, and was kicking the tires while I wait for my company to upgrade to premium capacity. From within paginated report builder, it looks like I have to embed the connection string for each report or link to a PBI dataset.
      Basically i’m trying to replicate what SSRS offers with me being able to configure the dataset, put it in a folder and share it/use it for all reports.
      Sam Duval
      Data Quality Analyst
      Indianapolis
    • Audrey Abbey
      September 10, 2019 at 10:59 AM
      If I am understanding you correctly, yes, this can be done.
      Performance might be an issue, depending on your environment.
      But you can use a Power BI model as a data source for other Power BI reports.
      Audrey Abbey
      SR. BI Developer/Analyst
      New Seasons Market
      Portland OR
    • Sam Duval
      September 13, 2019 at 7:15 AM
      Thanks . The only problem there is I have to select all the objects individually (I think). If I build the connection string in paginated report builder, I only have to connect to the database, I can then build the report and use anything on that server. In power bi I have to select each object I want to bring in, or write a sql statement. I was hoping there would be a way to just share a connection to the database for use in paginated.
      Sam Duval
      Indianapolis
    sam-duval replied 6 years ago 1 Member · 0 Replies
The discussion ‘Power BI Dataset’ is closed to new replies.
