I often have a problem when I need to pivot data in the Query editor. It seems to be a very basic task, but the “correct” solution eludes me everytime. I hope someone could show me a form of general solution to my problem.
I have 2 columns, let’s say a ‘category’ and a ‘value’.
Go to the transform tab and open pivot column under that useĀ value column and aggregate value function or you can choose your own to get the desired result.
sam
—————————— Sam Chatterjee Business Intelligence Developer Sam Analytiks (M):-(+45) 9163 4228 URL:- https://www.samanalytiks.com —————————— ——————————————-
John Fjord
April 9, 2019 at 5:02 AM
Thanks Sam,
But that is exactly my problem, I do not want to aggregate “Value”. So if I choose “Do not aggregate” under advanced, I get a table like this:
A
B
C
Error
Error
Error
This error being: “Expression.Error: There were too many elements in the enumeration to complete the operation.”
/John
—————————— John Fjord Instructor XLhaj Lyngby 31680770 —————————— ——————————————-
Doug Beardmore
April 10, 2019 at 12:23 PM
?Hi John,
Try this.
In the Add Column tab, select Index column, starting at 0 Then select Conditional column with the new column name “Row ID”, if Column Name “Cat.”, Operator equals, Value box type in A, change the Output typeĀ to Select a Column and choose Index. In the Otherwise box type in null. Click Ok. Click the Row ID column, from the Transform tab, Fill Down. Right click the Index column and Remove it. Click on the Cat. column and click Pivot Column, leave Values column Value, in the Advanced options select Don’t aggregate. Click Ok. Right click the Row ID column and Remove it.
Doug
h/t Gil Raviv’s Ā “Collect, Combine, and Transform Data Using Power Query in Excel and Power BI”, pages 177-179.
—————————— Doug Beardmore Quality Manager Janesville WI 608-755-1495 —————————— ——————————————-
John Fjord
April 11, 2019 at 11:14 AM
Hi Doug,
Brilliant, I knew there had to be someone who had the same challenge.Thank you very much. You saved my day.
—————————— John Fjord —————————— ——————————————-
Doug Beardmore
April 12, 2019 at 9:51 AM
?You’re quite welcome John. I’m glad I could help!
Doug
