Performing Calculations in M Language/Power Query
  • Performing Calculations in M Language/Power Query
    Posted by Unknown Member on July 15, 2020 at 2:18 pm
    • Fred LaValley
      July 15, 2020 at 2:18 PM
      I’m having trouble performing a calculation using M language in power query. It successfully calculates in the query editor, but when I “Close & Apply” it says there is some error.Ā
      When the Freight Key is Delivered and the Accrued Freight is 0, then I want to calculate and replace the Accrued Freight like this: Pounds Billed * .04.
      If this if/then doesn’t apply, then the freight remains unchanged.
      This is the formula:
      = Table.ReplaceValue(#”Month”, 0, each if [Freight Key] = “Delivered” and [Accrued Freight] = 0 then (each [Pounds Billed]*.04) else [Accrued Freight], Replacer.ReplaceValue,{“Accrued Freight”})
      This is the error power BI gives me while it’s attempting to refresh.
      screen shot of error message
      I don’t get it. If it works in the query editor, why doesn’t it work when applying it?
      F.L.
      Oakwood, GA
    • Gopa Kumar Sivadasan
      July 16, 2020 at 2:21 AM
      There must be a value in your referenced column source which is not of the data type for that column. In query editor, by default, only 1000 rows are loaded. Hence, if the error is in a row not within this 1000 rows, then no error is shown in query editor. But when you close & apply, the whole data is transformed, and it will throw an error.
      Please check in the source data for any data type mismatches.
      Gopa Kumar
      Limner Consulting
      North Kerala User Group Leader
      https://www.pbiusergroup.com/NorthKerala
    • Lutz Bendlin
      July 16, 2020 at 7:39 AM
      You have an extra “each” in your code.
      Lutz
    Unknown Member replied 5 years, 8 months ago 1 Member · 0 Replies
The discussion ‘Performing Calculations in M Language/Power Query’ is closed to new replies.
