I have an issue that just recently started, when I save a paginated report to PBI service, by default it is setting the gateway to be on, despite the fact that it’s using oauth to an azure sql database. Because it doesn’t map to a datasource, the report fails to work until I go and change the settings to turn the gateway off. Is there a setting somewhere that I can change to not default to trying to use the gateway for new reports?
—————————— Sam Duval Data Quality Analyst Element Financial Indianapolis IN ——————————
