Optimize the Dax Query
  • Optimize the Dax Query
    Posted by DSC Communities on March 14, 2023 at 1:03 am
    Optimize the Dax QueryFollow
    Sree Sree
    Sree SreeMar 14, 2023 01:46 AM
    Hi, Can anyone optimize the below query. it’s taking 15 seconds to load when I run in Dax studio. and …
    1. Optimize the Dax Query
    Sree Sree
    Posted Mar 14, 2023 01:46 AM
    Can anyone optimize the below query. it’s taking 15 seconds to load when I run in Dax studio. and this measure I am using for conditional formatting.
    CAGR = Var matrix1 = CAGR (% TY v LLY)]
    Var matrix2 =
    CALCULATE(CAGR (% TY v LLY)],
    ALL(‘STATES’)
    , ALL(‘STORES’)
    , ALL(‘PRODUCT’)
    Return
    IF(matrix1 > matrix2, “GREEN”, “RED”)
    Thanks.
    Sree Sree
    Software developer
    Bangalore SD
    2. RE: Optimize the Dax Query
    Bronze Contributor
    James Watts
    Posted Mar 14, 2023 06:38 AM
    It looks like you want Matrix2 to be calculated once for all data – if you make it a calculated column, it should all speed up.
    James Watts
    Business Intelligence Analyst
    3. RE: Optimize the Dax Query
    Sree Sree
    Posted Mar 14, 2023 07:40 AM
    Thanks James for your response.
    I want it in measure not as calculated column. and data loading from live connection (SSAS model.). if I create calculated column in model it occupies memory. So I need it in measure.
    Sree Sree
    Software developer
    Bangalore SD
    4. RE: Optimize the Dax Query
    Vilmar Santos
    Posted Mar 14, 2023 08:57 PM
    See if changing ALL by REMOVEFILTERS helps you
    Vilmar Santos
    5. RE: Optimize the Dax Query
    Sree Sree
    Posted Mar 16, 2023 05:41 AM
    Thanks Santos,
    Applied REMOVEFILTERS but not gives better performance. This is also executed same duration in runtime.
    Sree Sree
    Software developer
    Bangalore SD
The discussion ‘Optimize the Dax Query’ is closed to new replies.
