What measure could I use to just display the plain value from a column in my cards? I am having such issue with this whether I have it set to text or a number. All of my individual slicer categories work, but it’s the overall for each slicer category that won’t display right. I had created a slicer table to indicate that for instance all the engineering programs make up the overall engineering category and so forth through all the different degrees. I don’t need the first or last value, I don’t need the sum or average. I just want to display the value that is flat in my table. I have the settings set to don’t summarize already and nothing is working. The stupid thing is that I have all my tables and slicers set up the exact same way for other tables and all those visuals work and slice fine, this is the only thing left that is wrong. For this particular value column it HAS to be just the final answer, I cannot set up my data any other way in which an average would work or a sum would work. It basically has to be the final numbers I want to display rather than BI aggregating it.
