Moving Rolling Average
Posted by DSC Communities on January 20, 2020 at 9:18 am-
Matthew Wright
MemberJanuary 20, 2020 at 9:18 AM
Hello,ĀI have created a rolling average of our sales in Powerbi. It calculates the average for the last 3 months. My challenge right now is that it is calculating a rolling average for the current month and the previous 2. Where I really want it to do is to ignore the current month and create an average for the past 3. For example, this month is January I want to give me the average for Oct, Nov, and Dec.Ā
This is what I am currently using:Ā
Moving X Months AVG = SUMX(DATESINPERIOD(DSS_DATA[Run_Date],LASTDATE(DSS_DATA[Run_Date]),-3,MONTH),[Total Internal Samples])/3Any help would be greatly appreciated.
Matthew Wright
Business Director
9195046424
Hasham Niaz
MemberJanuary 20, 2020 at 9:40 AM
Hi Matthew !Use StartOfMonth() to find the start date of current month & then use DATEADD() function to get last day of previous month.
From there You can use the same Date to calculate past 3 months using already built DAX.
Hasham Bin Niaz
Director Data & Analytics
Karachi, Pakistan
Matthew Wright
MemberJanuary 20, 2020 at 10:12 AM
Hasham,ĀThanks. I created a measure to get the start of the previous month but its returning for me 12/1/2019. Also when I combine it with the current DAX measure the math is not working.Ā
PrevMonth = CALCULATE(STARTOFMONTH(Datestest[Date]),DATEADD(Datestest[Date],-1,MONTH))
Moving X TEST3 Months AVG = SUMX(DATESINPERIOD(DSS_DATA[Run_Date],[PrevMonth](DSS_DATA[Run_Date]),-3,MONTH),[Total Internal Samples])/3——————————
Matthew Wright
Business Director
9195046424
Hasham Niaz
MemberJanuary 20, 2020 at 10:39 AM
Hi !It should be something on the lines;
VAR LastDayofPrevMonth = DATEADD(STARTOFMONTH('Calendar'[Date]), -1, DAY) VAR FirstDayofLast3Month = DATEADD(STARTOFMONTH(LastDayofPrevMonth), -2, MONTH)
Now try to implement using above logic.
Hasham Bin Niaz
Karachi, Pakistan
Matthew Wright
MemberJanuary 20, 2020 at 10:52 AM
Hasham,ĀI appreciate your help. Apologies I am still very new to writing DAX and have only worked with VAR very little. How do I merge the two measures together?Ā
When I write the logic you suggested do I do that within the existing measure I wrote or do I need to create a separate measure?
Matthew Wright
Business Director
9195046424
Matthew Wright
MemberJanuary 20, 2020 at 2:59 PM
I have tried the following but no luck:ĀMoving X TEST3 Months AVG =VAR LastDayOfPrevMonth = DATEADD(STARTOFMONTH(DSS_DATA[Run_Date]),-1,DAY)VAR FirstDayofLastMonth = DATEADD(STARTOFMONTH(LastDayOfPrevMonth),-2,MONTH)RETURNSUMX(DATESINPERIOD(DSS_DATA[Run_Date],LastDayOfPrevMonth,-2,MONTH),[Total Internal Samples])/3——————————
Matthew Wright
Business Director
9195046424
Hasham Niaz
MemberJanuary 20, 2020 at 3:07 PM
Please share the sample fileRegards,
Hasham Bin Niaz
Karachi, Pakistan
Sergio Murru
MemberJanuary 20, 2020 at 3:20 PM
Hi Mattew,I think PARALLELPERIOD() could be what you are looking for
I hope this helps
Sergio Murru
TORINO
Robert Lamb
MemberJanuary 20, 2020 at 4:50 PM
Hi MatthewI found this article quite helpful – I adapted it to my needs (to calculate a moving range), but I have no idea *why* it works – good luck!
https://www.sqlbi.com/articles/comparing-with-previous-selected-time-period-in-dax/
Cheers
Robert
Robert Lamb
Lean Coach
Matthew Wright
MemberJanuary 21, 2020 at 8:17 AM
Robert,ĀThis is helpful thank you very much
Matthew Wright
Business Director
9195046424
Nicolas MENDEZ
MemberJanuary 20, 2020 at 5:31 PM
Hi Matthew,You cab try the formula below:
Rolling AVG 3M = CALCULATE ( [Total Internal Samples], DATESBETWEEN ( DSS_DATA[Run_Date].[Date], DATEADD ( STARTOFMONTH ( DSS_DATA[Run_Date] ), -3, MONTH ), STARTOFMONTH ( DSS_DATA[Run_Date] ) - 1 ) ) / 3 ?
Writing this I assume that the [Total Internal Sample] is a measure computing the SUM of Internal Samples. If yes, the formula above should OK, if no, I need more infos aboutĀ [Total Internal Sample] content
I hope it’s a good start for you
Nicolas MENDEZ
Data & BI consultant
Becom Consulting
Matthew Wright
MemberJanuary 21, 2020 at 8:16 AM
Nicolas,Ā
That worked like a charm thank you so much!Ā
Matthew Wright
Business Director
9195046424
Bhupendra Mishra
MemberApril 19, 2020 at 4:38 AM
Sir, can u assist in using AVERAGE func to re-write the same above——————————
Anubhav Mahule
Lead consultant
DSC Communities replied 5 years, 7 months ago 1 Member · 0 Replies -
The discussion ‘Moving Rolling Average’ is closed to new replies.
