Measure using multiple Var
  • Measure using multiple Var
    Posted by DSC Communities on June 23, 2020 at 5:22 pm
    • Brenda Britt
      June 23, 2020 at 5:22 PM
      I have two variables that I want to use, both variables are in tables that are not related to the data table.
      The CurrentDate variable is working correctly, but the CurrentPlant is not working correctly.Ā
      Total Stock Value Date =
      VAR CurrentDate = MAX(‘Fiscal Periods'[Month End Date])
      VAR CurrentPlant = MAX(Plant[Plant])
      VAR Result =
      CALCULATE(
      SUM(‘Inventory Coil Aging'[Total Stock Value]),
      FILTER(
      ‘Inventory Coil Aging’,
      ‘Inventory Coil Aging'[Posting Date] <= CurrentDate && ‘Inventory Coil Aging'[Plant] = CurrentPlant
      RETURN
      Result
      BrendaĀ
      System Data Manager
    • Vishesh Jain
      June 24, 2020 at 4:15 AM
      Does your Plant[Plant] column contain dates?
      Vishesh Jain
      Owner
      VR Construction
    • Brenda Britt
      June 24, 2020 at 7:07 AM
      No, it does not. We look at our data a a company level and then down the the Plant (location) level.
      Brenda Britt
      System Data Manager
      DeLand FL
      3524550343
    • John Thomas
      June 24, 2020 at 9:59 AM
      Brenda,
      The part in your “Result” DAX statement is asking…
      …Ā  ‘Inventory Coil Aging'[Posting Date] <= CurrentPlant
      How can a date value be equal to or less than the CurrentPlant?Ā  To ‘s point, this seems to be part of your issue.Ā  What sort of values are in the “CurrentPlant”?Ā  Text String of Plant Names?Ā  Plant ID Number??
      John Thomas
      Huntersville NC
    • Lutz Bendlin
      June 24, 2020 at 12:44 PM
      Remember that variables are impacted by their current filter context. So MAX(plant[plant]) usually refers to the current “row” in a visual, not an actual row in an actual table.
      Doesn’t really matter if you use MAX or MIN or AVG etc in such a scenario. You could even use SELECTEDVALUE() if you don’t care about totals.
      Lutz
    • John Thomas
      June 24, 2020 at 2:34 PM
      Brenda,
      It’s hard to answer your question if you just say “it’s not working”.Ā  Can you provide more details and a sample pbix file?Ā  What’s not working?Ā  Do you get an error or just the an answer you were not expecting?
      Are the variables you are using in a Slicer?Ā  If the tables (“Fiscal Periods” and “Plant”) are not related to the data table, then the MAX will just get you the max value from these tables.Ā  If you add a relationship from these two tables to your data table, then the MAX will return the row from these tables filtered to the current filter context of the data table.Ā
      Another approach may be to use LOOKUPVALUE.Ā  Without an explanation of what’s wrong or what you are getting and some sample data it’s hard to say what the issue may be.
      Here’s what LOOKUPVALUE might look like, but again, it’s hard to say without more informaiton.
      VAR _CurrentDate =
          LOOKUPVALUE(
            'Fiscal Periods'[Month End Date],
            'Fiscal Periods'[Date],
            MAX('Inventory Coil Aging'[Posting Date])
      VAR _CurrrentPlant =
          LOOKUPVALUE(
            'Plant'[Plant],
            'Plant'[Plant],
            MAX('Inventory Coil Aging'[Plant])
      John Thomas
      Huntersville NC
    DSC Communities replied 5 years, 9 months ago 1 Member · 0 Replies
The discussion ‘Measure using multiple Var’ is closed to new replies.
