Iterative/Recursive DAX Calculation
Posted by Austin Campbell on March 9, 2021 at 11:26 am-
Hello PBI Community,
I’ve been working on a seemingly easy but in reality a complex visual for awhile now. I feel like I’m very close to solving the solution but I’m at the point where I could use some help.
Basic Background:
- I am a Power BI Pro user
- I have a query that pulls current inventory levels
- I have a query that pulls expected sales forecast
- I have a query that pulls expected production forecast
- I have a query that pulls product hierarchy
- I have a date table that identifies production days from non-production days
My request is to build an actual/forecast table that (see Excel file for a detailed example):
- If month is historical provide ACTUAL ENDING INVENTORY
- This is based off the Inventory query
- If month is current or future provide a calculation
- Inventory = [Prior Month Inventory]-[Sales]+[Production]
Astute observers will recognize that my future calculation is an iterative or recursive calculation. DAX absolutely hates these types of circular dependencies and starts kicking up all sorts of errors. I have tried in vain dozens (if not hundreds by this point) different variations of DAX formulas to create the result but have always ended up in failure.
I recognize that a key component to solving this dilemma is based on the EARLIER equation similar to:
Sales Cumulative =
CALCULATE(
SUMX('SalesPlan'[SalesPlan]),
Ā Ā Ā Ā FILTER(
Ā Ā Ā Ā Ā Ā Ā Ā Ā ALL('SalesPlan'[Date]),
Ā Ā Ā Ā Ā Ā Ā Ā Ā EARLIER('SalesPlan'[Date])>=[Date]
Ā Ā Ā Ā Ā )
I have experimented with creating a “virtual” table via the VAR/RETURN similar to the following:
Ending Inventory =
//LOAD MEASURES
VAR _actuals = SUM(Inventory[Inventory])
VAR _initial =
VAR _maxDate = CALCULATE(MAXX(Inventory,[DATE],REMOVEFILTERS(Inventory))
Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā RETURN
Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā Ā CALCULATE(SUM(Inventory[Inventory],FILTER(Inventory,[Date]=_maxDate))
VAR _sales = SUM(SalesPlan[SalesPlan])
VAR _production = [AvgDailyProduction] * [ProdDaysInMonth]
//LOAD DATE VARIABLES
VAR _currentMonth = MONTH(TODAY())
VAR _startDate = FIRSTDATE(ALLSELECTED(Dates[Date]))
//TABLE CREATION
VAR _table1 = GENERATESERIES(_currentMonth,12)
VAR _table2 = ADDCOLUMNS(_table1, "Initial Inventory",_initial)
VAR _table3 = ADDCOLUMNS(_table2, "Date",DATE(YEAR(_startDate),[Value]+1,1)-1)
VAR _table4 = ADDCOLUMNS(_table3, "Production Cumulative", CALCULATE(_production, FILTER(_table3, EARLIER([Date])>=[Date])))
VAR _table5 = ADDCOLUMNS(_table4, "Sales Cumulative", CALCULATE(_sales, FILTER(_table4, EARLIER([Date])>=[Date])))
VAR _table6 = ADDCOLUMNS(_table5, "Shortfall Cumulative", [Sales Cumulative]-([Initial Inventory]+[Production Cumulative]))
VAR _table7 = ADDCOLUMNS(_table6, "Shortfall Cumalative Max So Far", MAX(MAXX(FILTER(_table6, [Date] <= [Date]), [Shortfall Cumulative]),0))
VAR _table8 = ADDCOLUMNS(_table7,"Closing Inventory",[Initial Inventory]+[Prouduction Cumulative]-[Sales Cumulative]+[Shortfall Cumalative Max So Far])
VAR _table9 = CROSSJOIN(_table8,Date)
RETURN
IF(SELECTEDVALUE(Date[Month Number])<_currentMonth,_actual,Maxx(_table9,[Closing Inventory]))
Ā FYI: this code resulted in providing actuals for historical months but generating 0.00 for future months
Ā I have included a sample excel file and sample .pbix file that provides a very basic example of my true file setup (most of my queries are derived from Oracle, SQL, and Excel).
Ā Also, as a point of record I’ve consulted the following webpages:
- http://blog.extrobe.co.uk/blog/2016/11/26/creating-virtual-tables-in-power-bi-using-dax/
- https://www.sqlbi.com/articles/from-sql-to-dax-projection/
- https://community.powerbi.com/t5/Community-Blog/Iteration-in-DAX/ba-p/1223311
- https://community.powerbi.com/t5/Quick-Measures-Gallery/Previous-Value-aka-quot-Recursion-quot/m-p/637614
- https://community.powerbi.com/t5/Community-Blog/For-and-While-Loops-in-DAX/ba-p/636314
- https://community.powerbi.com/t5/Community-Blog/Runge-Kutta-and-the-Limits-of-DAX/ba-p/357501
- https://community.powerbi.com/t5/Desktop/Recursive-Measure-PowerBI/m-p/637130
- https://community.powerbi.com/t5/Desktop/DAX-Create-a-measure-which-referencing-to-the-previously/td-p/204761
- https://gregdeckler.com/2019/03/06/previous-value-recursion-in-dax/
- https://stackoverflow.com/questions/61257536/how-to-perform-sum-of-previous-cells-of-same-column-in-powerbi
- https://www.edureka.co/community/86727/recursive-logic-in-dax
- https://www.youtube.com/watch?v=lyhS2txtZ44&t=3s
- https://www.sqlbi.com/articles/understanding-circular-dependencies/
- https://www.sqlbi.com/articles/avoiding-circular-dependency-errors-in-dax/
Austin Campbell
Manufacturing Data Analyst
Mebane, NC
919-304-7886
Marc Schroyen
MemberMarch 11, 2021 at 8:15 AM
Hi Austin,
You don’t need iterative or recursive calculation.
You need to setup the right filter context.
First, you need to get last inventory by product:
Inventory Last Date = VAR MaxDate = MAX ( 'Date'[Date] ) VAR MaxInventoryDates = CALCULATETABLE ( ADDCOLUMNS ( SUMMARIZE ( Inventory, 'Product'[Item #] ), "@MaxInventoryDate", CALCULATE ( MAX ( Inventory[Date] ) ) ), 'Date'[Date] < MaxDate ) VAR MAxInventoryDateWithDataLineage = TREATAS ( MaxInventoryDates, 'Product'[Item #], 'Date'[Date] ) VAR Result = CALCULATE ( SUM ( Inventory[Inventory] ), MAxInventoryDateWithDataLineage ) RETURN Result
You can find the explanation here: https://www.daxpatterns.com/semi-additive-calculations/
Once done, you have to calculate the forecastEnding Inventory = VAR MaxInventoryDate = CALCULATE( MAX(Inventory[Date]), REMOVEFILTERS(Inventory)) VAR MaxProductionDate = MAX(Production[Date] ) VAR MaxSalesDate = MAX(SalesPlan[Date]) VAR _actuals = SUM(Inventory[Inventory]) VAR _sales = CALCULATE( SUM( SalesPlan[SalesPlan] ), FILTER( ALL('Date'), 'Date'[Date] <= MAxSalesDate && 'Date'[Date] > MaxInventoryDate ) ) VAR _production = CALCULATE( SUM(Production[Production]), FILTER(ALL('Date'),'Date'[Date] <= MaxProductionDate && 'Date'[Date] > MaxInventoryDate ) ) VAR Forecast = Inventory[Inventory Last Date] + _production - _sales RETURN SWITCH( TRUE(), MAX( 'Date'[Date]) <= MaxInventoryDate, _actuals, Forecast )
Basically, you start everytime from the last inventory date and add production – sales up to the current month.
Alternative for forecast:
Ending Inventory = VAR MaxInventoryDate = CALCULATE( MAX(Inventory[Date]), REMOVEFILTERS(Inventory)) VAR MaxProductionDate = MAX(Production[Date] ) VAR MaxSalesDate = MAX(SalesPlan[Date]) VAR _actuals = SUM(Inventory[Inventory]) VAR _sales = CALCULATE( SUM( SalesPlan[SalesPlan] ), 'Date'[Date] <= MAxSalesDate, 'Date'[Date] > MaxInventoryDate ) /*VAR _production = CALCULATE( SUM(Production[Production]), FILTER(ALL('Date'),'Date'[Date] <= MaxProductionDate && 'Date'[Date] > MaxInventoryDate ) ) */ VAR _production = CALCULATE( SUM(Production[Production]), 'Date'[Date] <= MaxProductionDate, 'Date'[Date] > MaxInventoryDate ) VAR Forecast = Inventory[Inventory Last Date] + _production - _sales RETURN SWITCH( TRUE(), MAX( 'Date'[Date]) <= MaxInventoryDate, _actuals, Forecast )
Marc Schroyen
LiĆØge Belgium
Ā Thank you so much. These calculations solved my issue. I cannot express my gratitude enough!?
Austin Campbell
Mebane NC
9193047886
Austin Campbell replied 4 years, 5 months ago 1 Member · 0 Replies -
The discussion ‘Iterative/Recursive DAX Calculation’ is closed to new replies.
