Is it it possible to do it using Heat Map
  • Is it it possible to do it using Heat Map
    Posted by DSC Communities on September 10, 2019 at 6:25 am
    • Mohamed Azarudeen
      September 10, 2019 at 6:25 AM
      Hi, please find below data setĀ
      Location values
      A 1050
      B 1000
      C 1673
      D 1016
      E 1120
      F 1220
      G 1873
      H 2089
      I 3000
      J 4903
      K 2830
      L 5140
      M 1500
      O 1765
      P 2987
      Q 1101
      Based on this this data , i need show a visual likeĀ
      I need to show like above matrix . For example if data vale 1000- 2380= Show green color, 2381-3760 = yellow , and 3761-5140= Red color.
      Is it possible show like this in Heat map , I am new to power BI , so please guide me how to do it in heat map or any other option.
      Thanks and Regards,
      Azar.
      Mohamed Azarudeen
      BI Developer
      IV
      chennai
      9790777218
    • Simon Lamb
      September 10, 2019 at 1:10 PM
      Hi ,
      On your matrix visual you’ll have [Values] in the values bin, so click on the down chevron there and then on Conditional Formatting.Ā  You have options for background colour, font colour, data bars and icons.Ā  If you’re familiar with Excel’s conditional formatting then it should all make sense.Ā  Conditional formatting is also available from the Formatting pane.
      You should find everything you need there but let us know if you need more detailed guidance?.
      Simon Lamb
      IT Consultant, Method Excel Ltd.
    • Mohamed Azarudeen
      September 16, 2019 at 3:02 AM
      Hi ,
      Thank you very Much for your reply,
      Location Values
      A 44
      B 22
      C 66
      D 45
      E 55
      F 60
      G 20
      H 35
      I 56
      J 45
      K 56
      L 25
      M 10
      N 25
      O 45
      P 65
      Q 22
      Based on this data have to find out max ,min , and med=(max -min)/3Ā  ,
      1000+1380 = 2380 min+med=Green color
      2380+1380=3760 Green+med=Yellow color
      3760+1380=5140 Yellow+med=Red color
      Based on this condition can i create dynamic conditional formatting in Heat map below example
      If the actual data change the heat map color will change as per calculation condition , is it possible to do it Power BI.
      Thank you in Advance.
      Thanks and Regards,
      Azar.
      Mohamed Azarudeen
      BI Developer
      IV
      chennai
      9790777218
    • Vishesh Jain
      September 17, 2019 at 3:09 AM
      Hi ,
      Please check out the following article on how to use conditional formatting.
      https://docs.microsoft.com/en-us/power-bi/desktop-conditional-table-formatting
      If you scroll down in the article, you will see you can even use the DAX functions SWITCH() TRUE()Ā  in a measure in order to get conditional formatting.
      Hope this helps.
      Thank you,?
      Vishesh Jain
      Owner
      VR Construction
    • Mohamed Azarudeen
      September 17, 2019 at 9:44 AM
      Hi ,
      Thank you very Much for your reply .
      I have done the task using Dax measure.?
      Thanks and Regards,
      Azar.
      Mohamed Azarudeen
      BI Developer
      IV
      chennai
      9790777218
    DSC Communities replied 6 years, 1 month ago 1 Member · 0 Replies
The discussion ‘Is it it possible to do it using Heat Map’ is closed to new replies.
