Inflation calculation
Posted by DSC Communities on October 31, 2022 at 11:20 pm-
Vinu Hari
MemberOctober 31, 2022 at 11:20 PM
Hi All, I have an inflation table against each area, country.
On each anniversary date (i.e. Rate start + 365days or based on the end date) I wanted to add the inflation of 3% to Rate start or ever is indicated in the inflation table.Pls help in doing by DAX
The inflation % can be find in rate table
Ideally, the dax should calculate
if cost is 100
y1 – 100+0%
Y2 – 100+3%
Y3 – 103+3% and so on——————————
FA
Adam Artur Boltryk
MemberNovember 1, 2022 at 3:18 PM
Add column ‘Rate’ as ‘Base Rate’ + ‘Inflation cost’ and change logic for
‘Base Rate’ = LastYear(‘Rate’)
Also in screenshot you provided (year 2023 data) – if ‘Inflation_cost’ is 30 shouldn’t be ‘Inflation’ 3%, not 0%?you can make it š
Adam Artur Boltryk
Business Analyst
Kaz Shakir
MemberNovember 7, 2022 at 2:52 PM
I downloaded the .pbix file you attached, but I am having trouble understanding how the values in this file are related to your question.?Ā I am not able to see the columns that you show in your example in the file:- Is the “Area” column in your example, the same as the “Station” column in your file?
- Is the “Inflation” column in your example, the same at the “CPI YOY” column in your file?
- Is the “Base Rate” column in your example, the same as the “List_rate” column in your file?
- I don’t see anything called “Volume” in the file
- If my assumptions above are correct, then for the station = “CPT”, the inflation is never 3%, it’s always 0% – so where is that 3% coming from?
Could you provide some more information so that I can better understand how to use the information in your file to answer your question?
Kaz.——————————
Kaz Shakir
TN
Kaz Shakir
MemberNovember 11, 2022 at 5:12 PM
?I had some time to work on your question today, and here’s what I have been able to come up with.Ā I’m not sure if it addresses your request completely, but I think it gets several of the components you wanted.In order to create the inflation table you wanted, I had to perform a cross join of the values from the Rate Master table with the years from the Calendar table.Ā Then, I filtered out the years that did not apply for each station, and last I created a “period start” and “period end” column to correspond to the example table you provided.Ā Here is the code for this new calculated table:
Table 2 = SELECTCOLUMNS( ADDCOLUMNS( FILTER( CROSSJOIN( DISTINCT('Calendar'[CalYear]), DISTINCT( SELECTCOLUMNS( 'Rate Master', "Station", 'Rate Master'[Station], "Service Provider", 'Rate Master'[Service provider], "Rate Start", 'Rate Master'[Rate_start], "Rate End", 'Rate Master'[Rate_end], "List Rate", 'Rate Master'[List_rate], "Inflation", 'Rate Master'[CPI YOY] ) ) ), [CalYear] >= YEAR([Rate Start]) && [CalYear] <= YEAR([Rate End]) ), "Period Start", DATE([CalYear], MONTH([Rate Start]), DAY([Rate Start])), "Period End", DATE([CalYear], MONTH([Rate Start]), DAY([Rate Start])) + IF(MOD([CalYear], 4) = 0, 365, 364) ), "Station", [Station], "Service Provider", [Service Provider], "Period Start", [Period Start], "Period End", [Period End], "Base Rate", [List Rate], "Inflation", [Inflation] )?Then, I created a calculated column in this new table, to determine the first period for this station, like so:
First Period = VAR thisStation = 'Table 2'[Station] VAR thisProvider = 'Table 2'[Service Provider] VAR filteredData = FILTER( 'Table 2', 'Table 2'[Station] = thisStation && 'Table 2'[Service Provider] = thisProvider ) VAR firstPeriod = MINX( filteredData, 'Table 2'[Period Start] ) RETURN firstPeriodNext, I created a calculated column to determine the Rate at the end of the period (Rate eop) – this is why it was important to know the first period:
Rate eop = VAR yrsFromStart = DATEDIFF('Table 2'[First Period], 'Table 2'[Period Start], YEAR) VAR thisRate = 'Table 2'[Base Rate] VAR thisInflation = 'Table 2'[Inflation] RETURN thisRate * POWER(1+thisInflation, yrsFromStart)And finally, I created the “Inflation_cost” column from your example, like so:
Inflation_cost = 'Table 2'[Rate eop] - 'Table 2'[Base Rate]In the data model I connected this new table to the CC Master table, on the Station field:
And then I created a simple table using the columns from this new table.Ā In this screenshot, the table is filtered to Station = MCT, and Service Provider = AA1370:
I still was not able to find the column you called “Volume” in your example, so I will leave it up to you to fill in that portion of it.Hope that helps.
Kaz.
Kaz Shakir
TN
Vinu Hari
MemberNovember 24, 2022 at 12:52 AM
Hi Kaz, Thanks for your time and effort, one observationin 01/04/24 the base rate should be 133.90 (130+3.9) and inflation should be 4.02 i.e. 133.9 x 3% inflation.
The current dax gives a cumulative cost of 7.92 which is start rate 130 – end rate 137.92 – actually the inflation cost need to be considered only for the financial yearIs it possible to achieve
FA
DSC Communities replied 3 years, 5 months ago 1 Member · 0 Replies -
The discussion ‘Inflation calculation’ is closed to new replies.
