How to pass oracle “set role all” in Advanced Editor
  • How to pass oracle “set role all” in Advanced Editor
    Posted by DSC Communities on March 21, 2018 at 12:45 pm
    • Pepe Mujin
      March 21, 2018 at 12:45 PM
      Folks, ?I am struggling to pull some tables from an oracle database. I am required to pass somehow the following oracle statement:
      Set role all
      But when I try to do this, I got an error stating that this is not a valid sql statementĀ
      let
      Ā Ā Ā  Source = Oracle.Database(“mwks399083:1521/owr5000″, [HierarchicalNavigation=true, Query=”set role all”]),
      Ā Ā Ā  OWSYS = Source{[Schema=”OWSYS”]}[Data]
      in
      Ā Ā Ā  OWSYS
      Ā Expression.Error: This native database query isn’t currently supported.
      Please note that I am able to connect to the database..Ā  Any Advise will be greatly appreciated
      Best Regards,
      Jorge Castellano
      Jorge Castellano
    • Audrey Abbey
      March 21, 2018 at 3:09 PM
      Jorge,Ā
      I am not that familiar with Oracle, but I think that “SET ROLE ALL” is supposed to go in front of an actual SQL Query.Ā
      That should probably look something like:
      Query=”SET ROLE ALL; SELECTĀ  * FROM table; “
      You don’t have a valid query in your query string.Ā
      You just have the SET command.Ā
      Best,Ā
      Audrey
      Audrey Abbey
      SR. BI Developer/Analyst
      New Seasons Market
      Portland OR
    • Pepe Mujin
      March 22, 2018 at 3:47 AM
      Source = Oracle.Database(“mwks399083:1521/owr5000″, [HierarchicalNavigation=true, Query=”set role all; select * from dsd_norway.well_master;”])
      ?DataSource.Error: Oracle: ORA-00933: SQL command not properly ended
      Details:
      Ā Ā Ā  DataSourceKind=Oracle
      Ā Ā Ā  DataSourcePath=mwks399083:1521/owr5000
      Ā Ā Ā  Message=ORA-00933: SQL command not properly ended
      Ā Ā Ā  ErrorCode=-2147467259
      Jorge Castellano
    DSC Communities replied 7 years, 5 months ago 1 Member · 0 Replies
The discussion ‘How to pass oracle “set role all” in Advanced Editor’ is closed to new replies.
