Getting “Not Enough Memory To Complete This Operation”
  • Getting “Not Enough Memory To Complete This Operation”
    Posted by DSC Communities on May 5, 2018 at 9:21 am
    • Vishal Vaghasiya
      May 5, 2018 at 9:21 AM
      Hi All,
      I am getting below error while “DAX Formula” is Running into the Power BI Desktop.Ā
      “There’s not enough memory to complete this operation, please try again later when there may be more memory available.”
      ThereĀ is aĀ number of records areĀ 11,77,150.Ā  In “DAX Formula” where I markĀ duplicates with a sequential number.
      My System Configuration is 12-GB RAM & 64-Bit Processor.
      So, Please Help Me.
      Vishal Vaghasiya
      BI Developer
      9722111919
    • KAMAL MARU
      May 7, 2018 at 2:57 AM
      Hi Friend,
      i think there must be joining issue, that may be multiplying records, please check that
      KamalĀ
      +91 9810376859
      KAMAL MARU
      Team Lead – Power BI/MSBI/SQL
      HCL America
      New Delhi
      9810376859
    • Arjan Fraaij
      May 7, 2018 at 3:31 AM
      Could have to do with how you have you data model created in Power BI.
      To debug this do the following:
      1. Download and install Dax StudioĀ http://daxstudio.org/
      2. In you Power BI report create a blank report page and save the desktop file with this page open/selected
      3. Close All Power BI desktop sessions
      4. Start Power BI desktop again and open only this report LEAVE IT on the blank page!
      5. Start DAX Studio and connect it to the Power BI Desktop file you have issues
      6. In DAX Studio click the ALL Queries button
      7. Wait until output windows shows
      8. Now go to Power BI and start doing what you do while you are getting the memory error…
      9. When you have it return to DAX Studio and see what is on the All Queries page of your query trace…
      10. Find your longest running queries and analyze them…
      Arjan Fraaij
      Data Scientist
      Oosterhout The Netherlands
      +31162695354
    • Vishal Vaghasiya
      May 7, 2018 at 10:10 AM
      Thanks for the suggestions. There is no any joining issue or multiplying records and as well as I analyze the queries and it’s work properly with “DAX Studio” there is no any issue with DAX.
      Another way I tried this “DAX Formula” in another table where less amount of records then it’s executed. but when I try with more amount of record, it gives me a memory error. after then I run the DAX and see the “Task manager” then there is i found the issue of memory overflow even I have 12-GB RAM, so what I next to Do?
      Vishal Vaghasiya
      BI Developer
      9722111919
    • Audrey Abbey
      May 7, 2018 at 2:01 PM
      Post your DAX so that we can troubleshoot.Ā
      Just because it works on a smaller data set doesn’t mean it is efficient enough to handle larger ones.
      Audrey Abbey
      SR. BI Developer/Analyst
      New Seasons Market
      Portland OR
    • Vishal Vaghasiya
      May 9, 2018 at 1:19 AM
      =CALCULATE(COUNTROWS(Query), ALLEXCEPT(Query, Query[OPPORTUNITY_ID]), EARLIER(Query[RID]) >= Query[RID])
      This is my DAX.
      Vishal Vaghasiya
      BI Developer
      9722111919
    • Carl Loew
      May 8, 2018 at 10:01 AM
      If you are using Power BI Desktop, try increasing the Maximum allowed to 16000 under File / Options and Settings / Options / Global / Data Load.Ā  Data Cache Management Options.
      I ran into this issue once and this helped me.
      Carl Loew
      Commercial Credit Support
      TCF Bank
    • Vishal Vaghasiya
      May 9, 2018 at 1:34 AM
      @Carl Loew : I already try in “Data Cache Management” and increased the cache size but DAX still cannot execute.
      Vishal Vaghasiya
      BI Developer
      9722111919
    • Audrey Abbey
      May 8, 2018 at 6:53 PM
      I wonder if you are running into the background loading issue.
      File –> Options –> Current File –> Data Load.Ā
      Turn off Background data.
      Another potential cause:
      PBIX file –> Query Editor –> Right Click on Table –> Un-check Enable Load.Ā
      http://radacad.com/performance-tip-for-power-bi-enable-load-sucks-memory-up
      Best,
      Audrey
      Audrey Abbey
      New Seasons Market
      Portland OR
    • Vishal Vaghasiya
      May 9, 2018 at 1:38 AM
      @Audrey Abbey:Ā I try with your solution but still getting “memory Issues” and DAX can’t Execute.
      Vishal Vaghasiya
      BI Developer
      9722111919
    DSC Communities replied 7 years, 11 months ago 1 Member · 0 Replies
The discussion ‘Getting “Not Enough Memory To Complete This Operation”’ is closed to new replies.
