Get web data with login credentials
  • Get web data with login credentials
    Posted by DSC Communities on June 23, 2022 at 6:36 am
    • Leza Wood
      June 23, 2022 at 6:36 AM
      Can someone please explain how to connect to data on a website,  if login credentials are required?
      Thank you!
    • Warren Belz
      July 11, 2022 at 3:05 AM
      Hi ,
      If you are referring to the Launch() function, then your issue is “on the other end” where the owners of the target site may (or not) allow opening with credentials embedded in the URL. I suspect “may not” will be the result in most cases as login screens are generally designed as the form of authentication required.
      Warren Belz
      Queensland Australia
    • Leza Wood
      July 11, 2022 at 9:29 AM
      That makes sense. Thank you for your reply. ?
      Leza Wood
      Owner/Instructor
      Hudson Falls NY
The discussion ‘Get web data with login credentials’ is closed to new replies.
