Forecasting and perimeter
  • Forecasting and perimeter
    Posted by DSC Communities on July 29, 2017 at 12:46 pm
    • Jerome Charbonnier
      July 29, 2017 at 12:46 PM
      I’m trying to manipulate some forecast.
      forecastĀ
      The forecast (Somme Qty Prev) is inputted each month, with different labels (“06+06”, “07+05”)
      You can see the “Realised” and the “Forecast (Qty Prev)” in the blue columns.
      To be able to select and disaplay on old Forecast, I need to deselect the “Gray Line” that did not exist at this period.
      Each forecast, inputted with a dedicated label has a Ref forecast date “01/07/2017” in the case of “06+06”. The “Realised” Data has a unique date fixed to “02/01/2017”.
      There is a slicer to select the “Realised” value and the forecast to display.
      I tried several mesures (BFD = Beguin forecast Date)
      BFD1:=CALCULATE(MAX(Prestations[ref forecast date]);ALLSELECTED(Prestations[Ref forecast date]))
      BFD2:=CALCULATE(MAX(Prestations[ref forecast date]);ALLEXCEPT(prestations;Prestations[Ref forecast date]))
      BFD3:=CALCULATE(MAX(Prestations[Ref forecast date]);ALL(Prestations[Ref forecast date]))
      Qty measures should settled the right quantity depeding on the forecast selected date.
      QtyPrev2:=CALCULATE(SUM([Qty]);Prestations[BudgetRĆ©alisĆ©]=“Prev”;filter(Prestations;[BDF1]<=Prestations[Date]))
      QtyPrev3:=CALCULATE(SUM([Qty]);filter(prestations;Prestations[Date]<[BDF1]))
      As you an see, none of them is working, because at the “Realised” level, despite the beguining forecast displayed column, the real BDF1 used value is “02/01/2017”, the one of “Realized”.
      I am getting completely stuck.
      Any Idea?
      Thanks in advance
      Jerome Charbonnier
      Senior Manager
      Primis
      Neuilly sur seine
      0778473041
The discussion ‘Forecasting and perimeter’ is closed to new replies.
