Fetching items failed. Possible invalid string in filter query.
Posted by Unknown Member on August 11, 2020 at 5:34 pm-
This one has me baffled.Ā This is code that has worked flawlessly for over 18 months that is suddenly failing with the following runtime error:
“The requested operation is invalid. Server Response: [SPO datasource name] failed: Fetching items failed. Possible invalid string in filter query.”
I’m updating a SharePoint list from a collection.Ā Here’s a snippet of the code:ForAll(
colIndStateLicensingApproved,
Patch(
‘Individual Licensing States Licensed’,
LookUp(‘Individual Licensing States Licensed’,ID = colIndStateLicensingApproved[@ID]),
Title: Title,
StateLicensed: StateLicensed,
StateLicenseStatus: StateLicenseStatus,
StateLicenseNumber: StateLicenseNumber,
StateLicenseStatusDate: StateLicenseStatusDate,
OriginalLicenseDate: OriginalLicenseDate,
InterlincLicenseDate: InterlincLicenseDate,
CEYear: CEYear,
CEDateCompleted: CEDateCompleted,
RenewalYear: RenewalYear,
RenewalStatus: RenewalStatus,
RenewalStatusDate: RenewalStatusDate,
TerminatedInNMLS: TerminatedInNMLS,
NMLSTerminationDate: NMLSTerminationDate,
ProspectIUpdatedFiling: ProspectIUpdatedFiling,
ProspectSponsored: ProspectSponsored
);When I replaceĀ colIndStateLicensingApproved[@ID] with a hard-coded id, the code works.Ā I thought disambiguation was supposed to handle this situation – and it has until now.
What am I missing?
Larry Burgess
Developer
Interlinc Mortgage Services
Houston TX
281-210-5669
Will Page
MemberAugust 12, 2020 at 12:51 AM
Try replacing colIndStateLicensingApproved[@ID] with ThisRecord.ID——————————
Will Page
Technical consultant
Christchurch, NZ
Warren Belz
MemberAugust 12, 2020 at 1:20 AM
Hi Larry,Another thought – lots of Ambiguity in there – try an As statement
ForAll( colIndStateLicensingApproved As Approved, Patch( 'Individual Licensing States Licensed', {ID:Approved.ID}, { Title: Approved.Title, StateLicensed: Approved.StateLicensed, StateLicenseStatus: Approved.StateLicenseStatus, StateLicenseNumber: Approved.StateLicenseNumber, StateLicenseStatusDate: Approved.StateLicenseStatusDate, OriginalLicenseDate: Approved.OriginalLicenseDate, InterlincLicenseDate: Approved.InterlincLicenseDate, CEYear: Approved.CEYear, CEDateCompleted: Approved.CEDateCompleted, RenewalYear: Approved.RenewalYear, RenewalStatus: Approved.RenewalStatus, RenewalStatusDate: Approved.RenewalStatusDate, TerminatedInNMLS: Approved.TerminatedInNMLS, NMLSTerminationDate: Approved.NMLSTerminationDate, ProspectIUpdatedFiling: Approved.ProspectIUpdatedFiling, ProspectSponsored: Approved.ProspectSponsored } ) )?——————————
Warren Belz
Queensland Australia
the “As” statement did it!Ā It took me a couple of tries.Ā Apparently I typed something incorrectly the first couple of times.Ā Persistence paid off and now it’s working.Ā I still don’t understand why it worked for 18 months then suddenly stopped.Ā Oh well, such is life!
Larry Burgess
Developer
Houston TX
281-210-5669
Will, that gives me the same error.Ā The “As” statement that Warren suggested seems to have done it.
Larry Burgess
Developer
Houston TX
281-210-5669
Charles Palmer
MemberAugust 13, 2020 at 2:30 AM
Hi,Had something similarĀ – existing App, working for more than a year, suddenly stopped, exactly the same scenario – matching multiple collection items using ForAll.Ā
Ended up here on Google, and interesting that things happening at the same time.
I am using a secondary field to hold an internal reference to match on – which happens to be a GUID type string in a text field, but which has never been an issue before.
As suggested above things worked if I hard coded my filter values on either my internal reference or the ID fields.
I’ve had to useĀ GUID()Ā in the ForAll/Patch/Filter steps for the filter to work.
First(Filter(Works, GUID(job_id) = GUID(_offlineUpdateWork.job_id)))
UpdateContext(
_patchUpdateMaintResult: ForAll(
Ā _offlineUpdateWorks As _offlineUpdateWork,
Ā Patch(
Ā Ā Works,
Ā Ā First(Filter(Works, GUID(JobId) = GUID(_offlineUpdateWork.JobId))),
Ā Ā {
Ā Ā Ā Title: _offlineUpdateWork.Title,
Ā Ā Ā Description: _offlineUpdateWork.Description,
Ā Ā Ā Rating: _offlineUpdateWork.Rating,
Ā Ā Ā Comments: _offlineUpdateWork.Comments,
Ā Ā Ā Site: _offlineUpdateWork.Site,
Ā Ā Ā Status: _offlineUpdateWork.Status,
Ā Ā Ā BeforePhoto: _offlineUpdateWork.BeforePhoto,
Ā Ā Ā AfterPhoto: _offlineUpdateWork.AfterPhoto,
Ā Ā Ā CompletedDate: _offlineUpdateWork.CompletedDate,
Ā Ā Ā CheckUser: _offlineUpdateWork.CheckUser
Ā Ā Ā }
Ā Ā )
Ā )
Ā }
)(just in case it helps anyone else, as I’ve spent time trying various things / googling for ideas)
Charles.
Charles Palmer
Rob Clark
MemberAugust 12, 2020 at 3:25 PM
Apparently I cannot delete a post. I had speculation, but the problem has already been resolved I see.
Unknown Member replied 5 years, 4 months ago 1 Member · 0 Replies -
The discussion ‘Fetching items failed. Possible invalid string in filter query.’ is closed to new replies.
