Export Data to CSV from Power Bi report inside App
  • Export Data to CSV from Power Bi report inside App
    Posted by tyatsenko@newageindustries.com on August 19, 2019 at 9:01 am
    • Tetyana Yatsenko
      August 19, 2019 at 9:01 AM
      Is it possible for app consumers to export data from the table in Power Bi report, published inside app, into csv?
      We want to share reports through the app to prevent consumers from “accidental” report editing.
      Some of the reports contains tables.
      We would like consumers to be able to export the table in the csv within an app.
      Is there another options to share reports, with no-editing by consumers and permission to export data to csv at the same time?
      Everyone has a Power Bi pro Licence
      Thank you
      Tetyana Yatsenko
      Reporting Analyst
      NewAge Industries, Inc.
      Southampton PA
      2155262300
    • Martin Frisch
      August 20, 2019 at 1:58 AM
      by default it is possible with the export data function (click … on the upper right corner of the table):
      But as mentioned in that box there are some limitations regarding the number of records which can be exported.
      In the tenant settings it is possible to restrict that function only to specific user groups.
      Best regards,
      Martin
      Martin Frisch
      BI Developer
      Trützschler GmbH & Co. KG
    • Vishesh Jain
      August 20, 2019 at 4:02 AM
      HiĀ ,?
      Just to add to what said, .csv has a limitation of exporting only the first 30,000 rows while if you use excel the limitation is about 150,000.
      Just a pointer, before you make any decision.
      Thank you,?
      Vishesh Jain
      Owner
      VR Construction
    • Tetyana Yatsenko
      August 20, 2019 at 12:09 PM
      Martin, Vishesh, thanks for your suggestions!
      The “export data” was enabled in the admin portal.
      From the Report published in the Workspace I can export data into csv or excel:
      The same report was published in an app, and there is no option to Export data:
      Is it possible to enable “Export data from an App table”?
      Tetyana Yatsenko
      Reporting Analyst
      Southampton PA
      2155262300
    • Martin Frisch
      August 21, 2019 at 1:12 AM
      Yes this is possible, too. When you are using the default settings it should be possible, too. But additionally to the admin settings you can define on report level the export behaviour:
      Best regards,
      Martin
      Martin Frisch
      BI Developer
    • Tetyana Yatsenko
      August 21, 2019 at 1:15 PM
      Thanks a lot Martin,
      The original report was published in the Workspace, that I was a member of, not an owner.
      I republished the same report from the desktop into workspace, for which I am the owner, and made an app out of it.
      The export data is available from the app now!!!
      Tetyana Yatsenko
      Reporting Analyst
      Southampton PA
      2155262300
    • Hasham Niaz
      August 22, 2019 at 6:36 PM
      Also you can set the same setting on .pbix file itself a s well
      Setting is based on each fileĀ
      Go to File -> Options & Settings -> Options -> Current File -> [Allow end users to export both summarize & underlying data from the service or Report Server]
      Hasham Bin Niaz
      Director Data & Analytics
      Karachi, Pakistan
    tyatsenko@newageindustries.com replied 6 years ago 1 Member · 0 Replies
The discussion ‘Export Data to CSV from Power Bi report inside App’ is closed to new replies.
