Expand all | Collapse all sort by thread Construct a column based on values in two other columns using mCODE in Power Query
  • Expand all | Collapse all sort by thread Construct a column based on values in two other columns using mCODE in Power Query
    Posted by DSC Communities on April 18, 2023 at 12:13 am
    Construct a column based on values in two other columns using mCODE in Power QueryJump to Best AnswerFollow
    Rocking Mark
    Rocking MarkApr 18, 2023 07:02 AM
    Hope somebody can help me. I need some mCODE for Power BI to help construct a column based on two other …
    1. Construct a column based on values in two other columns using mCODE in Power Query
    Rocking Mark
    Posted Apr 18, 2023 07:02 AM
    Hope somebody can help me. I need some mCODE for Power BI to help construct a column based on two other columns in a data table. People were asked about eating Peas. They answered in different ways, some answers were text strings without spaces. I have the data in a table which details Names and the Answer returned by that name. I would like mCODE to constuct a column that gives an Answer “YES” if anyone of the same name in the table gives an answer that contains PEAS in the answer string, regardless of string case or string spacing. The mCODE should construct a column called “Yes or No”. The code should not rely on rows being listed in name or answer order. I give a sample of my massive data table below. One Fred answered “I like Peas” so all FREDS get assigned “YES”. No one called Anne Mentioned PEAS so all Annes Get assigned “No”. George’s Answer had no spaces but contained Peas so All Georges would get assigned Yes. Hope this Makes sense and Somebody can code this. Would Take a Dax Code Solution, but would prefer mCODE Thanks in Advance rockingmark
    Name ANSWER Peas Mentioned
    Yes or No
    Fred I like Peas YES
    Fred Beans YES
    Fred Don’t Like Toast YES
    Anne Like Bread No
    Anne Chocolate No
    Mark BEANS YES
    Mark don’t Like Peas YES
    TIM Choclate Yes YES
    TIM Tea YES
    TIM Coffees No YES
    TIM PEAS YES
    TIM Pizza horrible YES
    TIM Chips Yummy YES
    Sarah Yuk Mash NO
    Sarah Salty Corn NO
    Sarah Popcorn NO
    Sarah Carrots Nice NO
    Sarah dinner NO
    Bert PeAS YES
    Angie Sugar NO
    Angie Cars NO
    Angie I don’t eat breakfast NO
    GEORGE YESIEATPEASDONTYOU YES
    Rocking Mark
    2. RE: Construct a column based on values in two other columns using mCODE in Power Query Best Answer
    Bronze Contributor
    James Watts
    Posted Apr 19, 2023 04:40 AM
    Load the data.
    Create a column that checks if the text converted to uppercase contains “PEAS”, and set it to 1 if true, 0 if false
    Group the data on Name, and have a column that is the sum of this custom column
    Create a column that is “Yes” if the sum is 1, “No” if 0.
    Expand the retained Answer column.
    let
    Source =……
    #”Changed Type” = Table.TransformColumnTypes(Source,{{“Name”, type text}, {“ANSWER”, type text}}),
    #”Added Custom” = Table.AddColumn(#”Changed Type”, “HasPeas”, each if Text.Contains(Text.Upper([ANSWER]),”PEAS”) then 1 else 0),
    #”Grouped Rows” = Table.Group(#”Added Custom”, {“Name”}, {{“Peas”, each List.Sum([HasPeas]), type number}, {“All Others”, each _, type table [Name=nullable text, ANSWER=nullable text, HasPeas=number]}}),
    #”Added Custom1″ = Table.AddColumn(#”Grouped Rows”, “Peas Mentioned”, each if [Peas] > 0 then “Yes” else “No”),
    #”Removed Columns” = Table.RemoveColumns(#”Added Custom1″,{“Peas”}),
    #”Expanded All Others” = Table.ExpandTableColumn(#”Removed Columns”, “All Others”, {“ANSWER”}, {“ANSWER”})
    in
    James Watts
    Business Intelligence Analyst
    3. RE: Construct a column based on values in two other columns using mCODE in Power Query
    Rocking Mark
    Posted Apr 19, 2023 05:27 AM
    James, Thankyou so much for your time, worked first time in exactly the way I wanted. The summary of how to do it before the code is really useful. Helps us novices learn! Cheers, Mark.
    Rocking Mark
    DSC Communities replied 2 years, 3 months ago 1 Member · 0 Replies
The discussion ‘Expand all | Collapse all sort by thread Construct a column based on values in two other columns using mCODE in Power Query’ is closed to new replies.
