Error while connecting MySQL DB
  • Error while connecting MySQL DB
    Posted by DSC Communities on August 26, 2019 at 8:55 am
    • ganesh kumar
      August 26, 2019 at 8:55 AM
      Hi TeamĀ
      am getting below error while trying to connect mysql database .. please help me in this why am getiing this error..
      ganesh kumar
      Business Analyst
      9500990994
    • Martin Frisch
      August 27, 2019 at 1:27 AM
      what is the version of your ODBC Driver. I think at must be at least 5.1.Ā
      Best regards,
      Martin
      Martin Frisch
      BI Developer
      Trützschler GmbH & Co. KG
    • ganesh kumar
      August 27, 2019 at 1:48 AM
      i have installedĀ  “mysql-connector-net-8.0.17”?
      ganesh kumar
      Business Analyst
      9500990994
    • Hasham Niaz
      August 27, 2019 at 9:39 PM
      Hi !
      Please try setting up with my-SQL ODBC driver & see if its able to get you through.
      Hasham Bin Niaz
      Director Data & Analytics
      Karachi, Pakistan
    • Mark Toddy
      June 21, 2021 at 1:53 AM
      In some of the ways, spacing and the order of parameters in the MySql connection string does matters. So, stick to the standard format:
      MysqlConn.ConnectionString = "Server=localhost;Port=1234;Database=My_Mysql_Database;Uid=root;Pwd=root;"
      If the above connection string fails, try update your c# mysql connection string as shown below (without port variable as well):
      MysqlConn.ConnectionString = "Server=localhost;Database=My_Mysql_Database;Uid=root;Pwd=root;"
      Or, sometime the problem could be on your windows firewall, make sure your server allow access to all port associated with your mysql database.
      Mark Toddy
      Developer
The discussion ‘Error while connecting MySQL DB’ is closed to new replies.
