Display list of data across two columns to fit on one page
Display list of data across two columns to fit on one pageFollow
David Carr
David CarrDec 29, 2022 03:06 PM
I have (several) lists of data to display on a very simple report. I have two issues both with trying …
1. Display list of data across two columns to fit on one pageDavid Carr
Posted Dec 29, 2022 03:06 PM
I have (several) lists of data to display on a very simple report. I have two issues both with trying to get the data from these multiple lists to be able to display on one page.
(1) How do I make it so that, regardless of the number of rows returned in the query, that the report section dynamically expands.
(2) How can I spread the data across two columns?For example I have one list: New Cases, that has two columns (Owner and Contact). I don’t know how many rows will be returned.
I have a second list: Ongoing Cases, that has the same two columns, I’d like to be able to create a report list this:Table 1: New Cases
Owner Contact Owner Contact
Washington Dave Kennedy Julie
Lincoln Rich Ford BenTable 2: Ongoing Cases
Washington Paul Kennedy Joan
Lincoln JasonI don’t know how many rows will be returned, but I want to split the data across the two columns so that both have the same number of rows.
How can I define these report sections to spill the data from one result set across two columns?
Dave——————————
David Carr
Visionary Software Consulting, Inc.
Marylhurst
——————————2. RE: Display list of data across two columns to fit on one page
Bronze Contributor
James Watts
Posted Jan 03, 2023 06:15 AM
I don’t think you can dynamically resize visualisations in Power BI. If you use a paginated report you can though.To split the data into two columns, I would do something like:
– add an index column
– add a calculated column that is the MOD of the index column – MOD([Index],2) .
– this will give either 0 or 1 for each row
– create two visualisations and filter each to show either 0 or 1——————————
James Watts
Business Intelligence Analyst
The discussion ‘Display list of data across two columns to fit on one page’ is closed to new replies.
